Should this range considered too hot for my GPU/CPU?
12 minutes ago, MindUnited said:Thanks , also I check on the GALAX Website for my GTX 1060 3GB , it says "High Demanding Game" with 65~ C
http://www.galax.com/en/graphics-card/galax-geforce-gtx-1060-oc-3gb.html
does this means if it reach somewhere or exact 65 or more = should stop or just not that much?
Nah. The website states that 65C with demanding games is normal and to be expected. Anything lower is even better. Quick rule of thumb. A CPU should not reach higher then 90C on a hot day. Most people use a max temp of 80C, which is perfectly reasonable. Same goes somewhat for Graphic cards. Not higher then 90C and you are fine. The lower the better. I generally set my fan curve so it can never reach higher then 75C. (I tend to keep my GPU's cooler then my CPU's)
Anyhow, those are perfectly normal temps. Nothing to worry about.
