Need help troubleshooting
Go to solution Solved by Mira Yurizaki,
5 minutes ago, Morgoth97 said:
There's multiple entries all stating "WHEA_UNCORRECTABLE_ERROR" and are all caused by driver "hal.dll".
Thanks by the way, I really appreciate your input.
See if what's in this post is helpful: https://www.sevenforums.com/crash-lockup-debug-how/35349-stop-0x124-what-means-what-try.html
Some other places I looked at suggest opening Command Prompt as an admin and running the two:
  • sfc.exe /scannow
  • dism.exe /online /cleanup-image /restorehealth
To catch if your Windows install ran into corruption issues. And the usual "check for malware" and updating your drivers.
Hey, forum,
I've been having an issue with the PC I built (check signature for specification). I've been running this PC for a month now but I can't recall when the crashes began but they always exclusively happen when I'm running games.
The system would freeze and then reboot. Both CPU and GPU temperatures seem to be normal before and after the reboot; the CPU temperatures read 45 °C and the GPU temperatures read about 65 °C.
I have considered that perhaps my overclock was unstable but the system passed an Aida 64 test for 6 hours, a Prime95 test (Ver 26.6) for 3 hours (hovering 90 °C but didn't crash).
I've also considered perhaps my RAM was flawed so I re-seated the RAM and ran Memtest 86+ and the RAM passed.
TL;DR
System is freezing during games and restarting.
Things I tried:
- Updating motherboard's BIOS.
- Running Default settings (no overclock)
- Re seating the RAM.
- Re seating the GPU.
I would really appreciate your input on this.
Thanks in advanced,
Morgoth97
Laptop: MacBook Pro 13" (Early 2015) || Motherboard: Gigabyte Aorus x299 Gaming 9 || CPU: Intel i7-7820x (38% OC- 5.00 GHz) || RAM: Corsair Vengeance RGB 8GB @ 3466 MHz (x4)- DDR4  || GPU: MSI  Geforce GTX 1080 Ti Lightning X || Storage: Samsung 960 EVO NVME SSD 500GB || OS: Microsoft Windows 10 Pro || Chassis: Thermaltake The Tower 900 || Cooling Solution: Custom open loop water cooling system with a 560mm radiator and a CPU water water-block || Display: ROG Swift PG279Q || Pointing Device: Razer Mamba (2016) || Keyboard: Razer Blackwidow Chroma V2 || Headset: Astro A50 Wireless ||
https://linustechtips.com/topic/840682-need-help-troubleshooting/
7 minutes ago, dave_k said:
What is the "38%" overclock?
Some sorta auto-oc feature?
I meant I'm running a 38% overclock as in my multiplier was increased by a factor of 1.38 compared to stock multiplier (36) so basically 50.
I'm running at 1.36 v.
Just now, Morgoth97 said:
I meant I'm running a 38% overclock as in my multiplier was increased by a factor of 1.38.
Isnt that too high voltage for Skylake-X?
Who understands X299 chips, @done12many2 maybe or someone different?
Don't buy Apple M1 computers with 8GB of RAM
It is, I've seen people run 5.00 GHz at a lower voltage but any voltage lower then that would get me a blue screen.
1 minute ago, M.Yurizaki said:
If it reboots automatically, did you check your system logs for Bug Checks?
I've found an entry in event viewer:
The computer has rebooted from a bugcheck.  The bugcheck was: 0x00000124 (0x0000000000000000, 0xffffa20238b2c028, 0x00000000b2000000, 0x0000000000400005). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 00000000-0000-0000-0000-000000000000.
8 minutes ago, ImadKnight said:
Reset OC/BIOS and check if problem remains.
Sorry if I didn't make it clear. I did in fact reset the CMOS and ran the CPU with the default BIOS settings.
The error code translates to a wonderfully generic WHEA_UNCORRECTABLE_ERROR which means either you have faulty hardware or you have faulty drivers.
Since you have a crash dump, run WhoCrashed and it'll figure out what might've caused it.
  • sfc.exe /scannow
  • sfc.exe /scannow
Thanks, I'll look into it.
  • sfc.exe /scannow
Update:
The article helped a bunch. I'm running a Gigabyte motherboard so I figured to install gigabyte's App center as I found @BIOS very useful for safely flashing the motherboard but according to the article most of the Gigabyte Apps are the root cause  of the issue so I'll be uninstalling all of them save Gigabyte Fusion.
