There's an even bigger vulnerability that lies at the driver/software level......there are so many random bugs, glitches, and hitches, that if I didn't have as much self control as I did I would've thrown it out the window several dozen times over by now.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Might be a failsafe to try to protect the device from things like USB killer.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
Now try that with your desktop.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
I doubt this. Just because the software stops operating there's still physical connections inside the system. Plus a USB killer doesn't short the GND & +5V pins. It charges a bank of capacitors off it and then discharges them through the data + & - pins. The SurfacePro 3 would still get damaged.
I once stuck a piece of metal in the USB port of my MBP. It shut off and I had to unplug and replug the battery to get it to turn on again.
Might just be a failsafe to protect against shorts.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
The first version operated on GND and 5V. Second version operates on Data.
And I wouldn't exactly toss this in the unlikely bin. I had an Acer laptop from the Vista era that did this. Error log reported it as well.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
Fair enough. At the same time though OP didn't specify which pins are being shorted. Shorting 5V to a data pin or 5V to GND, or data + to GND. Depending on what is actually crashing the computer I just think it's more likely to be a fault rather than a feature. Especially if its had a reputation of previous issues.
Well, we've got 3 people, running 3 different devices, that had the same thing happen. Different hardware platforms, and software being ran. Either a common fault that's in most devices, or a safeguard.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
I think it's in the latest macbook where the USB C connectors are designed in such a way where if a USB killer is used on it it only damages the port itself but the rest of the system will continue to function without issue.
A feature where the OS crashes when pins get shorted is a pretty piss poor feature especially getting back to my original argument where this won't protect the hardware. The high voltage discharge will still rampage through the system and probably kill the motherboard if not some other components with it.
Likely not the OS itself, but firmware or hardware. As Doc's MBP wouldn't start without removing the battery first, same with my old Acer, it's likely that there is a trip that doesn't reset so long as it is powered. It'll also protect hardware from realistic shorts well enough that it's worth implementing.
Only if there is no failsafe, or you design something explicitly to kill a system and circumvent failsafes, like USB Killer 2.0.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
With news like that if I find a thumb drive it makes me want to crack it open and check the PCB before I plug it into anything.
I just tried, and my Surface Pro 3 (running Windows 10) doesn't have this problem.
I plug a USB cable, where the end is cut, and connected orange/red cable with the ground, I also tried connecting all wires together in a bundle... beside hearing small shock sound, system is fine, and USB port still work after plugging a USB Flash drive.
Now, we just need one more person willing to potentially kill their SP3's USB port to verify if your machine or OP's machine is the fluke.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
I don't expect the SP3 to be problem free... it is, at the end of the day the 3rd computer that Microsoft ever made. This is compared to countless systems and years of experience from all other OEMs. And heck, at every release of Surface product, it has all sorts of driver and firmware issues (always never before occurred issues). Microsoft has yet to master computer hardware testing.
I am just glad that they fixed the UEFI/firmware upgrade process issue of the Surface Pro 2, where in the end, once Microsoft got it working, they went in a "let's not touch this anymore.. it works", like it is walking on eggs. So, the Surface line is in this strange position. Fantastic hardware, great design, incredible how much performance they manage to pack in, while keeping decently good battery life... and despite the premium price, the firmware, drivers usually need many many months before all works fine.
I am just glad that they fixed the UEFI/firmware upgrade process issue of the Surface Pro 2, where in the end, once Microsoft got it work, they went in a "let's not touch this anymore.. it works", like it is walking on eggs.
Being 100% honest, the Surface lineup has been as dependable as the more reliable lineups of companies like Dell and Apple, with more issues being PEBKAC or third party softwares breaking something from everything I've seen.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
Tell that to my Surface that has nothing but One Note and Chrome Installed on it when One Note decides to act up, when it decides to drop wifi every five minutes, when it fails to recognize the keyboard is attached, when it fails to open the on screen keyboard when you click a text box, or when it loses connection to the pen.
PSU Tier List | CoC
Not just my machine. I shared the information with a few friends who have the same machine, and it is the same.
i like trains 🙂
Goodbyte's machine is probably a fluke then.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
