4 minutes ago, tommy3010 said:
Hi  all looking  to build computer for the kids not sure to go amd or intel it will be used for gaming and little photos editing
Absolutely amd at this point. A ryzen 3 1200 and a b350 mobo will go a long way, especially for photo editing.
Good luck!
-Lukas
1000$ PC: CPU:AMD Ryzen 5 1600 @3.6ghz Motherboard: Gigabyte AB350 Gaming-3 RAM: 16gb Corsair Vengeance 3000mhz GPU: Gigabyte GTX 1060 6gb G1 gaming Storage: 2tb Seagate Barracuda 7200rpm PSU: Corsair Vengeance 550m Case: NZXT S340 Black/Red Keyboard: Corsair Strafe w/ cherry mx browns Mouse: Steelseries Sensei 310
Something like this should be good enough for your kids...
https://pcpartpicker.com/list/c78rKZ
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($156.08 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($73.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($68.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($45.87 @ OutletPC)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card  ($144.98 @ Newegg)
Case: Corsair - SPEC-02 ATX Mid Tower Case  ($35.79 @ Amazon)
Power Supply: Corsair - CSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $565.68
Generated by PCPartPicker 2017-09-08 06:32 EDT-0400
Room to move, with hexa and octa cores on the B350 platform, and power supply wattage good enough for even a 1080Ti in the future.
idk
why is everybody recommending ryzen? jayztwocents proved that even a pentium will outperform a ryzen 1200...
what is your budget? and "gaming" is very vague. what games?
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
A 1080ti is not a good idea for 550w psu. yes i know that it will run perfectly fine, but with a cpu powerful enough not to bottleneck that card and then the card itself - the total system wattage is way above the efficiency curve of a 550w psu... it would work, but you gotta be realistic...
As others have said Ryzen 3 1200 and a B350 motherboard will be fine.
What's your budget?
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
What's your budget?
even a Pentium is better than that cpu. watch jayztwocents latest video.
She/Her
Huh? Even with an i7 4960X, this is the power draw numbers AnandTech got..
also - what the fuck does the efficiency curve have to do with this?
Did you pull that term off the back of a PSU box and decide to use it in a debate?
if it's about keeping efficient under a load of around 400-500w, you do realize that for 80+Gold certification, the PSU needs to be at least 87% efficient under full load that it is rated for.
idk
A Ryzen 3 CPU can easily beat a Pentium or i3 CPU. In some programs which are not optimized well enough, A Pentium may be slightly faster.
For the most part, a Ryzen 3 CPU is better than a Pentium or a Core i3 CPU.
JayzTwoCents is not the most reputable person on the internet. Countless other sources have proved that Ryzen is a great product compared to Intel.
I know how PSU ratings work, a psu is most efficient running between 50-60% of its total possible capacity. I know it needs to attain certain efficiency levels at higher wattages to gain its efficiency rating. however a 650W PSU would be much more efficient as, 400/650 * 100 = 61%. where as 400/550 * 100 = 73%. Those efficiency curves aren't just all marketing mayhem from manufacturers, they do hold an element of truth to them. a 1080ti with supporting system will run perfectly fine on a 550w psu, i have no doubts, but regardless of its efficiency rating, it will be far less efficient in its loss of power than a 650 PSU (and then theres overclocking to consider ;) )
Then again, it was evident in his video that the pentium is better in benchmarks and gaming - hes not just going to coin numbers from thin air, they are legit and reputable... the pentium probably wouldnt be as good in rendering (i dont have numbers) but thats due to a lack of physical cores on the pentiums side...
the pentium came out on top... why is that? did he not test with optimized games or something?
She/Her
While I agree that the headroom of a 650W PSU is sort of 'peace of mind' for OC.
Efficiency curve for this unit is very, very clean.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story3&reid=366
Check the bottom table, this is cold tests.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=366
And it has no trouble hitting Gold efficiency even in the hotbox hitting 41c.
idk
I agree it is a very good PSU, but as you said, for a complete picture covering all possibilities with that sort of high end hardware, you don't want to be cutting the psu wattage as fine as possible... regardless of whether it 'works fine' or not
Total: $565.68
This build is quite a good option btw... :) perhaps consider an SSD to throw in to make things that much better.
What is your budget? Do you need a os and peripherals as well as a monitor?
Sorry to ask this but, how old are your kids?
about 1000
16 hours ago, tommy3010 said:
about 1000
sorry mine-craft things like  that
On 9/8/2017 at 5:41 AM, TSL said:
What's the budget for this build?
1000 ish
13 and 1000 uk pounds ish
That test was not really proper it was all opinion based by the testers, also Ryzen can be OCed while Pentium cannot. :P
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
  • Intel build. Why Intel? Stability. AMD Ryzen has mature since launch. Imo, they need to mature some more, before it's safe to be suggest for a build.
  • 8GB of ram is good enough
  • Hybrid drive for that SSD like performance and the capacity of a HDD.
  • GTX 1050Ti for the games they play now as well as games they want to get in the near future
  • Windows 10 retail license, so it can be transfer, when you build a new PC.
  • Some matching parts, like mobo, case, and, gpu, to make it look nice and awesome.
  • IMO even a Kaby Lake Pentium dual core is good enough for your kids.
CPU: Intel - Core i5-7400 3.0GHz Quad-Core Processor  (£150.49 @ Aria PC)
Motherboard: Asus - STRIX B250H Gaming ATX LGA1151 Motherboard  (£100.67 @ More Computers)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-2666 Memory  (£67.50 @ Aria PC)
Storage: Seagate - FireCuda 1TB 3.5" 7200RPM Hybrid Internal Hard Drive  (£66.59 @ Aria PC)
Video Card: Asus - GeForce GTX 1050 Ti 4GB STRIX Video Card  (£161.84 @ Amazon UK)
Case: Cooler Master - MasterBox Lite 5 ATX Mid Tower Case  (£39.96 @ Amazon UK)
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£85.97 @ Ebuyer)
Operating System: Microsoft - Windows 10 Home Full 32/64-bit  (£100.37 @ More Computers)
Total: £773.39
Generated by PCPartPicker 2017-09-08 23:13 BST+0100
Ryzen 1600 for all those cores and excellent gaming performance (and the ability to overclock for extra performance), 16GB RAM @ 3000MHz so you can get the most out of the CPU and not worry about capacity in the future, 240GB SSD as a boot drive and a few other applications like a web browser for the snappy speed. 1TB HDD for mass storage of games etc, GTX 1060 6GB to get excellent gaming performance across the board in 1080p - no issues. Finally a beautiful tempered glass case to look stylish and a decent PSU.
https://uk.pcpartpicker.com/list/
Total: £773.39
i would add a 120gb ssd to this. other than that, it's a good build.
She/Her
what
fucking what
Ryzen is stable as all hell now, it's rock solid even for memory compatibility since agesa 1006.
idk
wouldnt recommend Ryzen for kids, even well knowledged people still fiddle with it. Buy something that has to be set once and keeps going ...
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
