networking Having trouble connecting 2 VM Ware machines
The
21 hours ago, Lurick said:You're on the right track I think but try putting IP addresses that are in the subnet your local machine is on which, if the pictures are correct for VMNet1, should be 192.168.145.0/24
21 hours ago, 101dmrs said:
So you tell VMWare to use the bridged interface. Then you go to your guest, which should just see it as any other normal interface and where you should be able to manage the network settings for that guest just like on any other windows install.
What you basicly do is taking a regular network interface, telling your hypervisor 'hey, this VM can use this regular interface' which says to your VM 'hey here is a network interface, all I and the host do is let you use it, we won't manage it for you and I'll let you think it's just any regular interface and you can manage it like it is just any regular interface'. So either you're trying the wrong things, or we don't comprehend each other, or I'm totally wrong in translating my Linux experiences into what might help on a windows machine.
I managed to solve the problem today. it didnt communicate because network discovery and file and printer sharing options were set to off in advanced sharing settings. i didnt know about this. putting both options to on state fixed it. Thanks for coming to help.
