EKWB A240 with a custom water cooled GPU
Go to solution Solved by For Science!,
4 minutes ago, Nigh74ury said:
lawl.
Can't believe you did that!! :D
I'm bored before going to sleep, so I did some maths for you too :P
Basically for the full copper loop you need:
https://www.ekwb.com/shop/ek-kit-p240 - 325.19 euro
https://www.ekwb.com/shop/ek-fc1080-gtx-ti-aorus-nickel - 116.83 euro
https://www.ekwb.com/shop/ek-acf-fitting-10-13mm-nickel x 2 - 9.12 euro or x4, if you want the extra rad
https://www.ekwb.com/shop/ek-coolstream-pe-240-dual - 67.07 euro (optional)
Totalling: 527.33 euro for a 2x 240 rad setup with a nice D5 pump. 451.14 euro if you opt not to get a second radiator
You can get the slim variant if you don't have space, it'll be a bit cheaper but you only get an SPC pump (same as the Fluid Gaming pump) its ok, but not great
https://www.ekwb.com/shop/ek-kit-s240 - 203.27 euro
https://www.ekwb.com/shop/ek-coolstream-se-240-slim-dual - 55.85 euro (optional)
So 394.19 or 329.22 euro
The equivalent for the dual loop would be....(going for cheap now)
https://www.ekfluidgaming.com/ek-kit-a240 - 172.73
https://www.ekwb.com/shop/ek-acf-fitting-10-13mm-nickel x 6 - 27.36 euro
https://www.ekwb.com/shop/ek-xres-100-spc-60-mx-pwm-incl-pump -77.19 euro
https://www.ekwb.com/shop/ek-duraclear-9-5-12-7mm - 15.19 euro
465 euro
Hey folks,
I was planning to go with fluid gaming EKWB A240G, but my GPU Aorus 1080 Ti is not yet compatible.
So, I was wondering if I could use a EK A240 for my CPU, and go with a different custom loop (preferably EKWB GPU Fullcover Water block) and TT / XSPC rads.
I have a ThermalTake Tower 900 case, so a dual loop would go nicer, and was wondering if I could use EKWB A240 on one loop and a separate PETG loop for my GPU, or would it lead to galvanic corrosion by using a non-aluminium block for the second loop?
Answers and suggestions are greatly appreciated.
Thanks in advance. :)
Best,
Nigh74ury
P.S: Adding @EK Luc @EK_Derick for expert opinion. xD
DON'T MIX METALS
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
6 minutes ago, Nigh74ury said:
Hey folks,
I have a ThermalTake Tower 900 case, so a dual loop would go nicer, and was wondering if I could use EKWB A240 on one loop and a different PETG loop for my GPU, or would it lead to galvanic corrosion by using a non-aluminium block for the second loop?
Best,
Nigh74ury
if they are 2 seperate loops itll be fine, otherwisd no
1 minute ago, JDE said:
DON'T MIX METALS
I'm with you there.
But would it really be "mixing" metals if they're on two different loops?
I would assume that "mixing" happens when a non-aluminum GPU block is used with the EKWB A240 loop, so water flows through the aluminum block, ionizes, and then goes through the non-aluminium block.
In that case, the entire case would have to be of the same metallurgical grade, which it never is!!
8 minutes ago, Nigh74ury said:
-snip-
Agree to the others as above, flat out no, unless you plan out a full dual loop (i.e. the GPU loop uses copper radiators, brass fittings, and a seperate pump). But this won't save you money (probably? I haven't done the maths) but I suspect if you do a dual loop, then a cost of a radiator + supremacy block is less than the dual loop.
1 minute ago, Nigh74ury said:
I'm with you there.
You're right there. Running them in two separate loops is fine. You only get an issue when the same water is flowing over aluminium and copper.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
When you say a full dual loop, does that include one of the loops as EKWB A240, and the other one a separate dual-loop for GPU?
I want to stress the point that, I would be against this too, because I prefer not to have different MET grades of metals. But the cost of a separate loop for a CPU (ideally: CPU Block + rads + pump res combo + fittings = ~350) would cost more than the CPU itself (paid ~300 for 7700K).
Just now, Nigh74ury said:
-snip-
Getting slightly confused but here is the nuts and bolts:
Okay --> A240 (Alu CPU Block, SPC Pump, Alu Radiator) + Full copper GPU loop (Copper GPU block, D5/DC/SPC pump, Copper radiator)
Probably cheaper:
Copper CPU block, copper GPU block, 2 copper rads, 1 pump
DUAL LOOP:
One loop - all copper/nickel/brass for GPU
and
One loop - all aluminum (EK A240) for CPU only.
Neither has any connections to the other.
ANYTHING ELSE:
Single loop, galvanic corrosion, and many other problems.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
7 minutes ago, Nigh74ury said:
=snip-
and FYI, all Thermaltake radiators are aluminium, so you would not want to use it with a copper GPU block, same issue.
Probably cheaper:
I'm slightly confused with this; How could one ever use 2 rads with 1 pump?
In one loop? You can use lots of radiators with only one pump, only thing is if you use like 4 or 5 rads you might need more pumps for more flow.
HOLA NIGHT THEMERS
OTHER TECH I OWN:
I thought most rads were aluminium, but I see a lot of copper rads too.
Would the ThermalTake rads work better with a PHANTEKS GPU block rather than an EKWB block?
https://www.overclockers.co.uk/phanteks-glacier-gtx-1080-ti-gigbayte-aorus-gpu-full-water-block-with-rgb-lighting-chrome-wc-01j-pt.html#tech_specs
Edit: There should be a line going from the 2nd rad back to the pump :P viva la ms paint.
Avoid thermaltake rads all together, they should not be used with any copper/nickel blocks
Radiators from EKWB, Hardwarelabs, Alphacool are all copper/brass, there are many more too, thermaltake is an outlier.
I can't say I've ever thought of it.
I have seen many builds with one loop, going through CPU & GPU block, then through a rad and back to the pump. What would the loop look like if one uses two rads with one pump?
Edit: Looks like @For Science! already answered it. :)
Edited by Nigh74ury
Already answered.
Looks like any other build to be honest, just more fittings and tubing
lawl.
That is a sweet build!
Doesn't this affect in cooling the CPU temps down since you're already pushing in warm water to cool the CPU down?
I can easily say I'm not as experienced as you are at water-cooling, and though your loops look great, I don't think I could pull it off. xD
Here, I have a great solution for ya.  Get the cheapest copper starter kit EK sells and the copper gpu block you were looking at (plus 2 extra fittings)
Want to custom loop?  Ask me more if you are curious
lawl.
465 euro
Nope, dont do it. ThermalTake radiator is aluminium and phanteks water block is still nickel plated copper.
With a powerful pump like a D5 or DDC, the water goes through the system so quickly that there are no temperature differences (major ones, anyway) in any segment of the watercooled loop. The whole loop gradually warms up and gradually cools down. This is why order of the loop doesn't matter and you don't need to have a radiator between each component.
I'm surprised at this!
I've seen so many builds with ThermalTake radiators & EK Blocks.
Edit: I wonder which GPU Block even goes well with TT rads. I've rarely seen any aluminium GPU blocks so far.
Edited by Nigh74ury
I suppose if you pump your coolant with anti-corrosives, then you are at the same level as AIOs. But it really is like "I wouldn't recommend you to jump a red light" you'll probably be okay for a while, but one day you may get hit by a car.
TT tried to address it by putting a sacrificial layer of zinc on it, but that caused some more problems with Pastel fluids.
http://forums.overclockers.com.au/showthread.php?t=1188197
Just don't do it, is my recommendation.
