2017 iMac (Radeon 580) vs. Custom PC (+Monitor)
Go to solution Solved by acls86,
Well, I'm using the new 2017 5k iMac with i5 and radeon pro 580. I'm just a casual gamer, but I know what I would get with a high end gaming pc. My last one was i7 7700k and 1080ti.
I just could not give up the 5k screen and whats more important, MacOS. If this matters to you, you have no alternatives.
For gaming I bought an external USB 3.1 SSD (Samsung t3), installed Windows 10 and there we go. I can play anything on high and ultra with a resolution of 1440p, the 5k screen scales superb with 1440p. Temperature in AAA games are around 85°C on CPU and GPU. Fan is not audible on desktop use, in games you can clearly hear the air (wushhh) but nothing like a low quality fan noise.
So much less cables!
Hello,
I am a HUGE Apple fanboy and I have been using iMac's since 2009s first 27inch iMac release. However, after watching Linus Tech Tips I am starting to get excited with the idea of building a custom PC. However, while comparing Apples to PCs, the iMac always seems to be a better value with significant benefits. I have my eye on one particular PC setup I have been thinking about getting over a new 2017 iMac and I would like your opinion.
*Screen quality is the most important factor* Minimum Size 27inch 4K
First I will compare the iMac vs PC in price (Canadian $) and specs
2017 iMac $3,241 +TAX
CPU - 7700K
GPU - Radeon Pro 580 8GB
RAM - 2400MHZ 24GB
SSD - NVME m.2 512GB
Screen (Built In) - 5K Resolution, 60HZ, 10bit, 500Nits, 27inches
Custom PC $2,800 +TAX | Monitor $1,400 + Tax | Total $4,200 + TAX
Canadian Computers and Electronics Custom 1080ti build - link
CPU - 7700K
GPU - Nvidia 1080ti 11GB
RAM - 2400MHZ 32GB
SSD- NVME m.2 250GB
HDD - 2TB
Monitor (XB321HK)- 4K Resolution, 60HZ, 10bit, 350nits, 32inches
The problem with the PC is that I will need a high quality display to go with my high performance new PC tower, a display that will easily put my budget over $1,000 more than the iMac at minimum.
iMac Pros
-Can run both Windows 10 and MacOS
-Perfect and easy tech support
-Amazing resale value
-Amazing industrial design
-No Viruses
-Monitor Included
-5K Screen
iMac Cons
-Lower performance graphics card
-None Upgradeable (Except RAM, Maybe CPU)
-Smaller Screen
I am just not sure which one to pick, they are both amazing machines.... Please help me pick. The custom PC is almost as much as the iMac but that isn't including the price of a 4K monitor.
What do I use the computer for?
Really basic stuff...
Browsing the internet
Playing games (Starcraft 2, EVE Online, Minecraft, VR)
It comes down to which operating system you need for certain programs (i.e. final cut pro x only runs on macOS) If that doesn't matter, I would go with the PC, just because you will have some upgradability in the long run (and PC's are awesomer)
Build
It
Yourself
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
well that 1080Ti is going to crush the Radeon Pro 580 (aka RX 580)
Actually with this years 5K iMac you can upgrade the CPU and RAM yourself (it just requires time and skill)
I personally prefer macOS infinitely more over Windows however if you are planning on gaming a lot the PC might be the way to go, however the iMac can play games extremely well at 1440p in Bootcamp.
The iMac also has the best screen on the market, a super fast SSD, and that Apple life style we fans know and love xD
(also Thunderbolt 3 and USB C) suck it PC users!
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | Car: 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
lowkey dying inside because you're a canadian and apple prices
if you are brave enough you can hackintosh,  but you will need to do some software 'hacking' (edit) to make the 7700k look like a 6700k for the iMac.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
You can run macos on a PC, I believe that's called a hackentosh or something like that.
You probably will get somewhat biased answers on here though, leaning towards PC.
My answer after dealing with macs at school, build a PC. You may get the 'I built this and I'm proud of it' that you wouldn't with a Mac.
Figure out if you can build a PC and install Hackintosh then you can have the best of both worlds.
you can but we are not allowed to talk about it on this forum :(
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
I've priced out a custom build PC and weirdly enough I only come in with a savings of about $50, and then lose that savings when I realize I have not installed Windows 10 yet aha. This particular pre-build custom built PC seems to be a cost savings unless I'm doing something wrong. Which I am indeed afraid to do on my first PC.
I thought that was only dealing with 'how to hackentosh' but didn't ltt do a video on a hackentosh though?
Use PCPartPicker. Much better prices.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
IMO if you're doing creative work, go with the iMac. That 5k screen is perfect for anything from graphic design to video editing. But, if you're gaming, go with the custom PC. You'll have far better performance with the 1080ti, as it's designed for gaming. If you do light creative work but mostly game, the PC will still be the better choice. Plus you can upgrade and expand it easily in the future. VS the iMac, you're sorta stuck with what you bought. (You can upgrade the 2017 model's CPU and RAM but you'd void your warrantee)
BTW yes viruses on the Mac.
A lot slower performance, 580 won't do 4K.
Full Specs
Helios EVO (Main):
Delta - Laptop
Pcpartpicker.com ? Try that for finding the best price.
CPU: AMD - Ryzen 7 1700X 3.4GHz 8-Core Processor  ($424.99 @ Amazon Canada)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($124.99 @ Memory Express)
Motherboard: Asus - PRIME B350M-A Micro ATX AM4 Motherboard  ($107.50 @ Vuugo)
Memory: Corsair - Vengeance LPX 32GB (4 x 8GB) DDR4-2666 Memory  ($294.99 @ Memory Express)
Storage: Samsung - 960 EVO 1TB M.2-2280 Solid State Drive  ($629.99 @ Newegg Canada)
Storage: Seagate - Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($101.50 @ Vuugo)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC Black Edition Video Card  ($909.99 @ Newegg Canada)
Case: Corsair - Carbide Series 88R MicroATX Mid Tower Case  ($58.99 @ PC Canada)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($89.98 @ DirectCanada)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($119.50 @ Vuugo)
Monitor: Dell - P2415Q 23.8" 3840x2160 60Hz Monitor  ($459.99 @ Newegg Canada)
Total: $3322.41
Generated by PCPartPicker 2017-08-02 01:02 EDT-0400
more ssd space, more storage, a better cpu for a mixed workload
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($378.99 @ Amazon Canada)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  ($134.99 @ Newegg Canada)
Memory: *Team - Vulcan 32GB (2 x 16GB) DDR4-3000 Memory  ($289.99 @ Newegg Canada)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  ($222.99 @ Amazon Canada)
Storage: Toshiba - X300 5TB 3.5" 7200RPM Internal Hard Drive  ($209.99 @ Newegg Canada)
Case: NZXT - S340 (Black) ATX Mid Tower Case  ($89.99 @ DirectCanada)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Newegg Canada)
Monitor: LG - 27UD58-B 27.0" 3840x2160 60Hz Monitor  ($469.99 @ Amazon Canada)
Total: $2931.90
Generated by PCPartPicker 2017-08-02 01:03 EDT-0400
Full Specs
Helios EVO (Main):
Delta - Laptop
Total: $3322.41
or that
Full Specs
Helios EVO (Main):
Delta - Laptop
Just now, JDE said:
or that
yeah just took me a second
I would still get my larger monitor though
Full Specs
Helios EVO (Main):
Delta - Laptop
some people want a small monitor with high PPI and others was larger
Let's be honest here, a similarly speced PC offers very little over this iMac. Finding a 5K display that good takes up a large amount of your budget right off the bat.
These new 5K iMacs are the best value computers Apple has made in recent memory. Dedicated graphics cards, upgradable CPUs, Upgradable RAM, a Full I/O compliment including USB 3.0 and Thunderbolt 3, and finally that absolutely stunning 5K display.
The Radeon Pro 580 (RX 580) is a great graphics chip and can game very well at 1440p.
Building a similar PC is possible, but it's still nowhere near as elegant.
but thermal management, you can't really game on it, it's more for productivity
Apparently it handles Battlefied (the new one) very well at 1440p (above 60fps)
Sure it will get warm but it can keep itself well under the thermal limit of the chips inside.
But it's at 5K, not 1440P
Full Specs
Helios EVO (Main):
Delta - Laptop
I know that 5K screen and industrial design is the just impossible for me to get over. The only screens which I think will be able to compete will be the upcoming Asus PG27UQ 4K 144HZ HDR G-Sync monitor with 1000Nits. But that monitor is a whole other beast on its own, not to mention the cost of the monitor will be well over $2K in Canada aha.
I refuse to downgrade screen quality after using iMac's for so many years, I just sold my 2015 5K iMac and ready to upgrade now.
