Hi guys.
i have an i5-6600k and gtx h110i
 the problem is that the cpu keeps overheating and the usage keeps reaching 100%, every time i start my computer , the picture down below illustrates the situation
for more details regarding the problem, please check my previous topic .
thanks in advance
https://linustechtips.com/topic/801836-cpu-100-usage-problem/
so what is the problem?
close the core2 program or deinstall
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082469
First off, what is that "Core2" program? I have never seen that program before.
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082470
Just now, Anas Dweik said:
i dont think its a program because i cant find it, and i never downloaded it
You can click on it in task manager. Right click and go to file location and see where it is. Then right click it in task manager and click force close
Smoking weed at the red light like its legal
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082482
Well, right-click on it and click on "Go to file location" to get an idea of what that program is called, and uninstall it.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082484
dude...
right click it and click on open path(or whatever its called in english)
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082489
Yeah that seems like a virus to me. I would definitely end that task and run antivirus software. If you don't have any you can use the free version of melwarebytes or Windows defender if you are on windows 10. Another option would be to reinstall windows and it should fix the issue.
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082503
11 minutes ago, Anas Dweik said:
Hi guys.
thanks in advance
if all else fails, backup and reinstall
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082509
i already scanned my pc, and no threats were found
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082513
4 minutes ago, Anas Dweik said:
what about the registry editor apps that also appear ,sometimes they reach 20 in numbers.
1
1- reinstall windows
2- use window defender+ ublock origin+ Adblock( remember to turn this off on your favourite YouTubes like LTT)
Norton is a virus
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082554
i think the best thing to do is make a backup, reinstall windows and scan the files you backed up, also be very careful of what you install, and NEVER just press "next, next, finish", that is how 99% of people get infected with malware, which if accepted unbeknownst to you, can run without detection from the antivirus (unless its really good) as it thinks its a program you allowed, and isn't disrupting critical files.
you could spend time cleaning it, but in my experience, a fresh reinstall of windows 10 takes about the same time or less, and is less hassle
Personal Rig Specs
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082564
Norton is a virus
you may consider it a virus, and it sure as hell is basically malware in some instances, but it won't disrupt your computer or encrypt your files for a ransom or anything, so giving out false information, even if its with the best of intentions, isn't helping.
Personal Rig Specs
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082576
2 minutes ago, Anas Dweik said:
not sure what you are trying to say
if you don't have anything decent to say don't say anything at all
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082593
don't reinstall any cleaners (except for maybe CCleaner) or ram boosters or plugins or anthing.. be absolutely sure what a program actually does before you install it.. and if you can't find it from a repetuble download service like techpowerup for instance, don't trust sites like superdownloads4000.megaserver.illinfectyou.cn
Personal Rig Specs
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082601
The file location of registry editor.
as i stated before
https://linustechtips.com/topic/801836-cpu-100-usage-problem/#findComment-10082606
