fan GPU FAN FAIL - WON'T STOP SPIN AFTER USE!
Solved by henriksen67,
SOLUTION:
Problem was resolved by removing the GPU from the PCI Express slot, remove the power cable to the GPU and then put the GPU back in the PCI Express slot and reconnecting the power cable.
Featured Topics
Xrniu ·
7
3
bleedpurple ·
Posted in Storage Devices2 -
geoffery ·
Posted in Troubleshooting1 -
IPQ ·
Joey__ ·
Posted in Troubleshooting5
