1 minute ago, H0R53 said:
https://www.amazon.com/gp/product/B019K0PQLS/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=AZCEI3EMXUPTH
Are these any good? Does anyone have any positive or negative experience with these?
Yeah they are good to be replaced
Never heard of that brand before
And PSU should not be trusted with experience, they need professional reviews
Definitely sounds like your house will need its power replaced after you use that PSU...
Maybe along with the rest of the house too, after it burns down.
They're cheaply-made garbage-tier PSUs, one of the brands that makes "OEM replacement" power supplies for nonstandard units. On a scale of one to forest fire, I'd put them somewhere near "unattended campfire surrounded by open cans of gasoline".
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
One good response and two "I don't know" responses.
Where does John Wick firefight fit in?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Utter crap.
Probably 300-400w max even if it says 775-800w
also number of connectors should tell you what they think it can do.. ex for your 775w psu:
Connectors: 1 x 20/24 pin, 4 x 4-Pin Molex, 1 x FDD, 4 x SATA, 1 x 8-PIN (4+4) EPS12V, 1 x 6+2 Pin PCI-e
When's the last time you saw a psu with a single pci-e 8 pin connector (150 watts max)? You often get 2 for 550-650w and 3-4 with 850w+
voltage select on back = no PFC , not or minimal input filtering, not even 80plus bronze eff. , ancient design
thin cables (probably awg20) and no sleeve on some to be cheaper
when's the last time you saw those generic warranty stickers on psu corners on anything quality?
28 minutes ago, mariushm said:
Utter crap.
I'm equally amused by the power distribution by rail. Quality PSUs (hell, even most shitty ones) will tell you how much of that 775W is going down each rail. This power supply, according to the pictures on Amazon, pushes 850W across all rails combined, with no specific breakdown. Two further huge red flags there: one, there's no indication how much power is supplied to each rail, and two, this 775W PSU is actually an 850W PSU...or they have the wrong pictures posted and God only knows what's going to show up on your doorstep.
1 hour ago, STRMfrmXMN said:
It looks like it has LEDs. It also looks like a fire hazard.
Yeah, I am not getting it. I bit my tongue and bought a 600W EVGA model, I'll probably swap the internals with a blank shroud to get rid of the ugly EVGA everything.
Like I get it that some people don't get certain cases cause they are too gamer-y but EVGA...calm yo tiddies.
