mITX case designed for air cooling??
23 minutes ago, blankcheck said:
@Zyndo I'd like a recommendation from you as well
Tough to say really. The things I like and look for in a case may very well be different than what you're after. Also have no real clue of what your budget is, or what kind of build aesthetic you're after.
Take a look at the picture posted by @GlassBomb just now. That is a great example of what I meant by getting around the PSU interference situation in the Define S by using a blower style cooler. Since blower styles have only one fan located at the far right side of the card, they are unfettered by the bulk of the PSU blocking any air to the left side of the card (where an open-air card would have fans located). they're also great for ITX builds if you're worried about airflow since they do not contribute any hot air to the case.
All that said, Here are some recommendations I could make to you for the few things I know you may want. I'm unsure what your price range is, but i'll just drop some links to cases I like and you can cross the ones off that are too expensive or otherwise do not meet your criteria:
https://pcpartpicker.com/product/CRfp99/corsair-case-cc9011061ww
https://pcpartpicker.com/product/fGvRsY/thermaltake-case-ca1b800s1wn00
https://pcpartpicker.com/product/VH2rxr/fractal-design-case-fdcadefnanosbkw
https://pcpartpicker.com/product/2kTrxr/phanteks-case-phes215pbk
https://pcpartpicker.com/product/KsTmP6/bitfenix-case-bfcpro300kkxskrp
This case has only 125mm CPU clearance so it may not be what you're looking for... but I think its unique, and interesting, so I figured its worth mentioning in case maybe its your thing.
Most of the above cases come in a variety of colours with windowed and non-windowed variants so you also have some flexibility if something isn't quite how you like it. These are not, by any means, the only good cases on the market. These are merely ones I like, have heard good things about, and (I think) meet the criteria you may be interested in. If your budget is a bit higher you may also consider looking into some Lian-Li cases as they're pretty slick... but they're certainly not for everyone, and they will leave your wallet a bit lighter.
