Controlling a Molex fan
5 hours ago, J.Munslow said:So in my build i have 3 fans powered directly by the motherboard and one that is powered by a molex adapter. i like to turn my fan speeds waaaaaay down so that my pc is near silent but obviously this isn't an option for my molex fan. i was wondering though if i could source a 4 pin fan header to molex adapter that would let me take control of this fan, or would that not work?
The easiest way to do this would be as suggested below:
5 hours ago, Electronics Wizardy said:Just get a resistor and put in in the Dan lead or most the connector to run off 7v or 5v.
To mod the lead, simply move the pins in the plug.
Assuming that your fan has a red +ve and black -ve wire, then the following applies:
12v (highest speed; most noise):
red -> yellow
black -> black
7v (lower speed; reduced noise):
red -> yellow
black -> red
5v (lowest speed; lowest noise):
red -> red
black -> black
This is all explained in more detail with pictures here (hope linking to other forums is allowed - i'm new here...)
This isn't adjustable on the fly though (unless you wire in switches to change the pins), but should achieve what you're after.
As mentioned above though, the most elegant solution would be one of the below:
- Buy a better fan, as they can be had for ~£5, and plug into either a spare motherboard header, or one that is being used by utilising a splitter as linked above.
- Buy a fan controller and take on the fly control of all of the fans at your disposal.
HTH
Josh
