gtx 1080 sli for z170 or x99 better
Solved by done12many2,
18 minutes ago, rotexen said:i own an i7 6700k with msi z170 m7 and a single gtx 1080 ftw.
is the 6700k good enough for sli to get another gtx 1080.
or go with an x99 build?
The 6700k is perfect for it. The cards will run at x8 + x8 in SLI, but there's little to no loss with that.
If a 7700k handles a 1080 Ti SLI well, a 1080 SLI will be no issue for a 6700k. I had the 1080s before the 1080 Tis.
