Silence optimized case
1 hour ago, GrayTech said:Hello.
I'll replace my laptop with an Desktop PC and since I want to have a silent environment when I'm working I decided to get a semi passive PSU and GPU. But now I asked myself how big the difference is between an silence optimized case like the Define R5 and a case which isn't. Anybody here replaced a non silence optimized case with a something like the R5? I would really like to know the difference.
Thanks!
Having built several dead-silent systems the case really doesn't matter much. The best use for a silent-optimized case I've seen is for a system with a lot of desktop hard drives that rattle and thus the rubber dampening for them is useful, or in a system with coil whine which thick foam on the side panels quells a lot.
Better airflow is what keeps components quieter and the Define S has airflow in spades while also having foam and rubber and all that good stuff. I'd recommend it.
