Delta fan future build
Solved by Enderman,
7 minutes ago, Cooling with Delta said:Oh and i found a converter from 12v to 48v but it also gives off 3 amps while the fan uses 48v to 0.97amps. Would that be a problem or do i need to find exact voltage with amparage to fit the fans power raiting?
3A output?
As long as its above the fan current it will work.
It's better to have more amps frmo the power supply, it won't heat up as much.
Featured Topics
2
INotPablo ·
Posted in CPUs, Motherboards, and Memory7 -
Marie Rose ·
Posted in Cases and Mods5 -
4
HayLo995 ·
Posted in Storage Devices4 -
8
Mortal_2077 ·
Posted in Displays3 -
Brexy9 ·
Posted in Power Supplies2 -
Brexy9 ·
Posted in Graphics Cards1
