Delta fan future build
Solved by Enderman,
7 minutes ago, Cooling with Delta said:Oh and i found a converter from 12v to 48v but it also gives off 3 amps while the fan uses 48v to 0.97amps. Would that be a problem or do i need to find exact voltage with amparage to fit the fans power raiting?
3A output?
As long as its above the fan current it will work.
It's better to have more amps frmo the power supply, it won't heat up as much.
Featured Topics
naldo29 ·
Posted in Troubleshooting0 -
1
MahdiC ·
Posted in Networking1 -
1
Sychicyuto ·
Posted in Troubleshooting2 -
ItzEager ·
Posted in Troubleshooting3 -
TheIndecisiveMollusk ·
Posted in New Builds and Planning1 -
4
Agall ·
Posted in CPUs, Motherboards, and Memory4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
