Help with 5GHZ OC 7700K
Solved by paddy-stone,
Temp isn't a problem, even if you hit 100 all that would happen is thermal throttling, but can't see it happening unless you happen to be in a country where the ambient temp at the moment is very low and summer is going to increase that by a lot... and that's if you don't have A/C?
If neither of the above applies to you, then it's completely fine, you will not see that in normal usage.
Featured Topics
Agall ·
Posted in CPUs, Motherboards, and Memory2 -
3
xKempo ·
Posted in Troubleshooting0 -
5
Dcorrigan97 ·
Posted in Troubleshooting1 -
Davidf4e ·
3
3
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
