Hello,
I have an old Core 2 Duo with motherboard and PSU with 2 gb ddr2 ram PC and looking to create a home Nas /Server to store videos and photos. I would need at least 1 tb of  secure storage (raid1) or raid 5 multiple drives for about 3-4 Tb storage. What would i need on top of what I already have and how dificult would it be ?
I don't have much server experience :)
Thanks in advance for all the help
https://linustechtips.com/topic/761638-old-core2duo-build-help/
5 minutes ago, Flavlus said:
tb of 100% secure storage (raid1) or raid 5
raid doesn't do this, backups do.
Id just install something like openmediavault and use that to manage the drives. You can setup raid in there. Don't use the raid on your motherboard.
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624006
6 minutes ago, Flavlus said:
Hello,
I have an old Core 2 Duo with motherboard and PSU with 2 gb ddr2 ram PC and looking to create a home Nas /Server to store videos and photos. I would need at least 1 tb of 100% secure storage (raid1) or raid 5 multiple drives for about 3-4 Tb storage. What would i need on top of what I already have and how dificult would it be ?
Freenas is very easy to use.
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624009
Yes raid 5 does. you can lose up to 1 drive and all teh data can be rebuilt. Raid 1 also stores 2 copies on 2 different drive ?
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624015
still won't help at all if you have randsomware, delete a file, the house burns down, or the os has a problem and craps over your data.
You need backups, not raid
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624023
raid =/= secure was his point
it's not drive failure, it's drives actually losing power at the same time or power surge that's the issue, making it not 100% secure.
I'd get some RAID cards or SATA cards and run them through PCI-E, probably better than what's onboard on that machine
idk
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624025
Ok and a backup on second drive helps if your house burns down and if your OS screws something up on one drive what says it wont on the other drive at the same time ?
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624030
offline backups and offsite. Backup to a hdd, store it at friends house or a safe deposit box.
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624036
Nothing in this world is 100% secure so yeah? im not sure what your argument for actual 100% secure is as literally no storage in the world is
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624038
sounds good .. ill go to my friends house a few times a day to access stuff and make sure its all backed up. Raid 1/5/6 are the only realistic safe storage options for realistic home server/Nas use.
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624045
no thats not how it works.
you make a backup to a external drive and store it there, then you replace it every month. you don't use that drive when you want data. Use raid when you want more capicity with multiple drives, not data security.
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624057
Do i need a specific raid card ? what should I look for? Are certain onses not compatible (probably will just be 7200 rpm drives in raid 5 ) or 2 1tb in raid 1 and the rest in someting like raid 0
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624058
a month of data is way to much to lose in terms of a drive faliure
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624060
dont' use a raid card, use software raid with onboard sata. If you need more ports get a hba. any drives will work.
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624066
Anything modern will handle Raid5 fine, go for anything. Used server HW is a plus for reliability however
idk
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624068
not really though. Id trust software raid more than a hardware card. The big advantage of hardware raid is speed(won't matter for a home nas) and os support(things like esxi and winserver pre 2012)
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624085
true, but I'm talking about cheap sata cards off ebay, etc.
idk
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624160
I will probably be using someting like free nas or something similiar
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624195
id probably use openmediavault. Its more flexable, runs better on lower spec hardware and has better compatibility due to linux. It also allows more types of raid, so you can mix drive sizes if you want with something like snap raid + merger fs
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624206
+1 for OMV, it's a solid OS.
idk
https://linustechtips.com/topic/761638-old-core2duo-build-help/#findComment-9624209
