Help. Best way to clean a noctura NH d15. Finger oil stains
Solved by WoodenMarker,
8 hours ago, Enderman said:It would make it look like brushed aluminum instead of polished aluminum.
That's only if the scrubbing is even. It's pretty easy to mess up.
2 hours ago, vESP said:in the end if that 1 plate causes me to loose 10c of cooling ill be pissed if i fix it lmao.
Any difference in cooling would be negligible.
Featured Topics
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting3 -
2
1
6
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
3
7
2
Shane Martin ·
Posted in Displays2
