Need help with h100i v2 install
Solved by MVPernula,
As far as I can see the USB part isn't necessairy unless you want the corsair link features, and if it works the same way as the H100i you can plug it in to begin with, set it to the color you want and then unplug it, the color will stay.
If you want to change color:
- Plug in the USB from the pump
- Install Corsair Link
- Set color
- Turn off
- Unplug USB from MOBO and pump
- Turn on
If the color is fine:
- Unhook the USB from MOBO and Pump
- Plug in front USB
- Gogogo
ALSO!
If you want us to see your answers, quote us. You do this by pressing the small arrow under the comments.
