Too much power draw?
Solved by Oseth,
ALRIGHTY!!! Got it figured out. The second socket in the wall outlet has bad wiring. Tried to plug everything, 3 PCs, router and modem, into a single newly aquired surge protector and so far no issues at all. I checked my breakers and as it turns out they are nearly all 20a glass ones, so I guess YAY??
Anyways, everything is running smoothly. Thank you all for the feedback.
On 1/20/2017 at 9:16 PM, Electronics Wizardy said:Its probably a bad wired house. Id get a electrician to take a look.
