I have never had a multi-GPU system so I am wondering how different cards can run folding in the same rig when you can only install the drivers for one of them? How can you even have an AMD and NVIDIA card in the same system when only one can have drivers installed?
As always, thanks in advance for your help!
Folding stats
Vigilo Confido
https://linustechtips.com/topic/724385-question-about-multi-gpu-system/
40 minutes ago, Tb428 said:
why not F@H will benefit from the extra horsepower of the SLIed gpus otherwise there is no way I know of to run them on the same os.
I want to run 3-4 750 tis because they are low wattage and I can get them on the cheap. However, they are not sli- capable :/
Folding stats
Vigilo Confido
then there is no way i know of to use all the cards with one system but there may be a way
I remeber a video on LTT about a folding machine where they used different brand gpus in one system. Did they virtualise each of them?
Folding stats
Vigilo Confido
I would check out FAH's site. Here is a snippet  about multiple GPU's and how FAH utilizes them. Link included at bottom.
What about multi-GPU support?
Yes, both cards can be utilized for Folding@home. Each GPU card will be given a separate Work Unit to process. In the older v6 client, adding the “-gpu N” flag (N starts at 0) would tell the client which GPU to use for folding. In the newer V7 client, the installer should automatically detect a multi-GPU setup and will configure itself to use them. Sometimes it has difficulties with mixed brands of GPUs. When this happens, our Guide pages may be helpful.
To adjust the configuration, change V7 to advanced mode using the drop-down menu in the upper right-hand corner, then under Configure -> Slots, edit the GPU slot and adjust the indicies. If you need help, consider posting in our Folding Support Forum.
https://folding.stanford.edu/home/faq/faq-nvidia/#ntoc16
You can't use folding at home in sli mode the newest version will just assign a work unit to each graphics card.
you do not have to run your graphics card in sli tough there are more setups where one of the gpu renders one half of the screen and another the other half and there is a third option too but I don't know how that works.
10 hours ago, Tb428 said:
only one card will work at a time unless you use a virtual machine os like kvm or unraid then one will be assigned to each vm you can watch linus's video on 2/7/8 gamers one cpu for more info on this.
This is so wrong... this is just SO wrong.... You can have as many GPUs as you want in the system; so long as each card is supported individually, the F@H client will give each and every one of them a WU to crunch. Even if they are AMD + Nvidia cards.
F@H does not benefit from SLI/CF. They benefit from more GPUs, that's true, but it'll do so regardless of a SLI or CF being enabled.
That's not a very good way to go about it. If you do the math, you'll realize that a single, stronger GPU (say, a 1060 or perhaps a used 970) will do better in the PPD and PPW department when compared to multiple 750tis.
8 hours ago, Tb428 said:
if this is the video your talking about im not sure how they did it but it does seem possible.
8 hours ago, Nicnac said:
Yeah that's the one
Reminder that this video is pretty bad...
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
^ Agree with above.
I never did the mixing of AMD and Nivida, but I have run several different Nivida cards in the same rig and had them all folding.  Plus, first thing that usually gets said on folding forum sections: turn the blasted SLI/CF off and make darn sure maximum performance power delivery is selected in the driver options.
2023 BOINC Pentathlon Event
F@H & BOINC Installation on Linux Guide
My CPU Army: 5800X, E5-2670V3, 1950X, 5960X J Batch, 10750H *lappy
My GPU Army:3080Ti, 960 FTW @ 1551MHz, RTX 2070 Max-Q *lappy
My Console Brigade: Gamecube, Wii, Wii U, Switch, PS2 Fatty, Xbox One S, Xbox One X
My Tablet Squad: iPad Air 5th Gen, Samsung Tab S, Nexus 7 (1st gen)
3D Printer Unit: Prusa MK3S, Prusa Mini, EPAX E10
VR Headset: Quest 2
Hardware lost to Kevdog's Law of Folding
OG Titan, 5960X, ThermalTake BlackWidow 850 Watt PSU
  • 4 years later...
I can confirm that multiple GPUs work just fine. I'm running an old modded GTX 750 and my main RTX 3060. The biggest issue is installing the drivers (GeForce Experience and Windows will battle over which driver/graphics card to use) but once both work, you'll have to restart the system and ensure you have one of the newest versions of F@H. If you didn't use an advanced setup, the client should create 3 cores, one for the CPU and one for the GPUs each. It's much more clear in the Advanced Control than in the web control. Happy folding 🙂
whoa, now that's a thread necro if i've ever seen one!
