Engineering project to design a CPU cooler
Hello everyone, I am new to the forums here, but I wanted to gather as much information as I can. I am in the Engineering academy at my school and for the semester-long project, I chose to design a CPU cooler. It'll require a lot of research but I am committed to this project. I am in the information gathering stage, so I am trying to get as much people to reply to the survey. If you have any suggestions to the survey, please, I would love to hear them! Thank you!
https://docs.google.com/forms/d/1T_lnWsveKv9v7ZzpBAVCMnIzUucRZruCxf6-9m9a6N0/edit
AX1600i owner. https://docs.google.com/spreadsheets/d/1_GMev0EwK37J3zZL98zIqF-OSBuHlFEHmrc_SPuYsjs/edit?usp=sharing My WIP Power Supply Guide.
https://linustechtips.com/topic/718314-engineering-project-to-design-a-cpu-cooler/
Sounds like a cool project! :D
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
it should have zero fans.
for copper vs aluminium have a look at test results for the original scythe ninja; it came in both ali and cu; the cu cost 2X more at retail and only delivered 1-2C difference.
ψ ︿_____︿_ψ_
Thermal Peltier CPU cooler would be cool.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
Replied to the survey, and like I mentioned in the survey you should target a delta over ambient instead of a specific temperature with a specific CPU ;)
Doing that means the testing become CPU independent, that's easier to test and design :)
If you need help with your forum account, please use the Forum Support form !
How many fans should it have:
You forgot the most important one: 0 ;)
But my needs for cooling are diffent from most people so don't listen too much on me.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
I should clarify, by peltier I meant a fan powered solely by the heat of the CPU.
Black Knight-
Daughter's Rig;
