HELP! 6700k dead!
19 hours ago, Energycore said:Ok time for a test
Sit the CPU on the socket without its IHS. See if you can get to the POST screen and if you can, the CPU is saved and you should carefully redo the thermal solution. Of course since there is nothing cooling the CPU, you should cut power immediately after you hit the POST screen.
I left the IHS on while trying, and the CPU does not get hot, does not post, it's like the MoBo isn't recognizing anything is there
10 hours ago, faziten said:Id first check the socket for bent pins. Its quick and easy to do. Already did it? Do it again from different angles.
Sit the IHS and close the socket retention arm slowly and steady. See if it presses both sides as it should without any play involved.
Add TIM on top of the IHS and just put a heatsink on top (dont screw it in, hold it down with your arm weight ) and attempt to boot (stock bios, do a clear CMOS first to guarantee there is default settings in place). This way you are discarding the possible uneven pressure. If it posts, kill the power and screw your cooling solution (and repeat the P.O.S.T test). If not, we are on the same spot and have rethink options.
At this point, you could assume it dead, so you should be finding the exact thing that went wrong. Uneven tension is the first obvious one that comes to my mind with a floating IHS and slightly bent PCB.
I'm with you on your last statement. Motherboard is fine, CPU was tested in 2 motherboards, 6600k works fine in both as well, IHS was definitely seated properly, I think it's a bent chip.
5 hours ago, done12many2 said:
Call me crazy, but the corner adjacent the top left notch appears discolored. Does it look a bit charred in person?
It does not, it is just a crappy phone camera shot (my LG v20 which boasts about its camera is surprisingly not great)
On a side note to everyone, I was at Fry's this AM and got their very first 7700k sold (I was there 10 mins before opening and was the only one there for that purpose). While I would really love to fix my 6700k (I actually have a spare z170 MoBo, I could build a whole system out of it) I think it's completely dead. Thanks all for the help, but I think it's time to call it a loss.
