PSU fan not spinning under full load!
Solved by Energycore,
2 hours ago, Tech Wizard said:I tried this, and it didn't spin here as well. I might mention that a GPU bottleneck happened when Aida64 pushed CPU usage to 100 %, so GPU load never exceeded 40-50 % in Fire Strike.
That makes sense.
2 hours ago, Tech Wizard said:To all 3 of you: It literally says on the box of the PSU that its suppose to start spinning when I pull 300W, and not certain temps. See picture in main post.
Also from what you guys said, the PSU fan is not spinning because it's not getting hot enough, correct? Means I have decent airflow
Your PSU fan is not spinning because you're not pulling 300W
