Throttling, again possibly but not sure.
Solved by Shadow_Storm56,
It's just boiNC. some of the projects are a bit odd and will even read 100% cpu useage when you can tell by Temps its for sure not.
Featured Topics
Gat Pelsinger ·
Posted in Laptops and Pre-Built Systems0 -
Mumintroll ·
Posted in Windows2 -
mr.happy ·
Posted in Power Supplies4 -
3
300DaysToGTA6 ·
Posted in Storage Devices5 -
5
1
1
4
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
