HDR looks much dimmer than SDR on my TV
Solved by Stahlmann,
This TV can only do about 300 nits peak in both SDR and HDR. Because HDR generally focuses more on the lower light range and uses the higher nit range only for highlights, content typically looks dimmer than SDR at the same peak brightness. This is because SDR brightness is relative to your display, while HDR brightness values are generally absolute, with only the peaks changing according to the capabilities of your display. This is true for any display with similar peak brightness between SDR and HDR, not just this one. But most good HDR displays have significantly higher peak brightness in HDR than in SDR, so it's not much of a problem.
