What is a "Vapor Chamber" cooler?
Solved by Guest GRRigger,
Vapor chamber where the heat contacts the liquid and the liquid vaporises. It goes into heat pipes where it condenses because its cooled down. Then its liquid again and the cycle continue.
Or it can be just a chamber without heatpipes, but the cooling is done by heat fins on top of chamber where the vapor condenses.
It is same as when you cook something. The water vaporises (at certain temp), when it tuches the lid that is lower temp, it condenses and fall down.
Also, if its higher pressure, the liquid needs higher temp to vaporise.
If its near vacuum, then it needs only room temperature to boil. Yep, water can boil at room temp.
