power supplies How much PSU Wattage for this 1070 SLI build with custom loop?
Solved by Zyndo,
7 minutes ago, Wolfieeee said:So should I get a rm1000i just to be safe or just keep the 850i?
I would not make that upgrade. such a small upgrade for a lot of money. I would personally go HX or AX 1200i, or a similar offering from EVGA or another company if you're looking to upgrade (both for extra headroom and better efficiency rating/better place on the efficiency curve). Or I would just recommend not getting super cray overclocks on your GPU's and keeping your current PSU.
