Help! JavaScript Looping through Numbers
Go to solution Solved by Mr_KoKa,
for(i=0; i<num; i++)
  number[i] = num; //Think about this line
You prompt user for input once, you set num variable once, so when you iterate from 0 to num - 1 and set every index of number array to num there is no surprise that all indexes are equal to num. It is i variable what changes trough iterations, it goes from 0 to num - 1 so to set it form 1 to num you would need to add 1.
I am trying to loop through a number that a user enters.
For example if a user enters the number 45. It should start a 1 and go through 45. (1,2,3,......45) .
ANY guidance would be appreciated.
The code that I have sets the results on a table(Thanks to VorticalBox and Mr_KoKa help).
It loops through but does not display the increments.
So if I enter 8. it shows the number 8 times(88888888) not 12345678.
Thanks again.
function testQuestion2()
	//empty array to store our numbers
		var number =[]
		var num = parseInt(prompt("enter number"))
		//loop x times
			//store each input in the array
			number[i] = num;
		//start of list
		var ul = document.createElement('ul');
		//loop every item in array
		for (i=0;i<number.length; i++)
			var li = document.createElement('li');
			//adds current array item to the page
			li.innerHTML = number[i];
			ul.appendChild(li)
		//end of list
		document.body.appendChild(ul);
https://linustechtips.com/topic/676538-help-javascript-looping-through-numbers/
He is right ^^^ number should be set equal to i, which is the one that is increasing.
Okay, I see Mr_KoKa.
Reason why we want to go by i is because i is the counter and is keeping track of the numbers it has to go through loop. SO if user enter 5 for a number. "num" stores the 5 and "i" tells it as long as i is less than num (5) keep on going....12345!
I get it, Thanks again Mr_KoKa.
