best not too-expensive compound to clean thermal paste from CPU and acc.?
For cleaning, 70% purity or higher would work, but ideally you'd use something with 95% purity or higher, the price difference wouldn't be big.
You won't find 100% purity because isopropyl alcohol likes to absorb water from the air and through pores in the plastic bottles, and during the brief moments you keep the bottle opened. Companies usually buy the alcohol in barrels and then from barrels goes in tiny bottles and that's another point where purity goes down slightly.
Alcohol also evaporates quite fast so even if you buy one liter, it's not going to last for years, it will very very slowly leak evaporate, unless you keep it in glass bottles and fully sealed etc.
If you can't source isopropyl alcohol, you can use plain old sanitary alcohol you can buy at any pharmacy, but you need to make sure it's fully evaporated before applying thermal paste or setting the heatsink over the cpu.
Isopropyl alcohol is the main ingredient in rubbing alcohol, which is sold to be used for babies but usually it's mixed with some kind of perfume. It's also used by veterinarians a lot. You can try asking for rubbing alcohol without perfume and other added substances from the pharmacist. Or you could go to a vet and ask them to fill a tiny bottle for you and they'll probably do it.
