Outdoor ethernet cable (withstand -30C)
Member
Hi,
I am planning to run ethernet cables out of my house for IP cameras. The winters in my area can get to -30C (-22F).
The cable will probably run in conduits to the soffits. What type of ethernet cable is recommended for outdoor -30C temperatures?
Any other suggestions welcomed!!!
thanks
Desktop: i5 4670k, Z97-K, 16GB, MSI GTX 770, Evga 850G2, TT T31
Freenas Server: i3 4170, X10-SLL-F-O, Crucial 16GB UDIMM, 4x4TB WD Red, Evga 550GS, Fractal 804
Peripheral: K60, HyperX Cloud
Mobile: Nexus 6P
Belden has somewhat of a guide on their website:
https://www.belden.com/resourcecenter/documents/upload/Industrial_Ethernet_Cable_Solutions_Brochure.pdf
7928A appears to be rated for extreme temperature applications.  I'm personally not sure what that means in the practical sense though.  Perhaps read the entire guide, in which most cables are rated down to -40C "operating".
There's a few cable types you'll want to avoid as they're only rated down to -10C.  Again, take a good look at the guide.  Maybe call your electrical supplier and/or even Belden up and see if their salespeople have a more specific recommendation.
BTW, OMFG is that 7928A stuff expensive.  Unless I'm reading something wrong, a 1000 foot box will set you back about 2 grand.
Dang
Mobile: Nexus 6P
Yeah definitely do more research.  I'm not convinced its totally necessary and/or there may be alternatives.  Ordering stuff from the "industrial" catalogue is basically a sort of cash cow for the cable vendors, because "industrial" people will write the cheque without thinking twice.
Thanks for your help, I will try to ask some people around my area.
Mobile: Nexus 6P
https://www.amazon.com/CERTICABLE-OUTDOOR-NETWORK-WATERPROOF-CONNECTORS/dp/B00FX6Y6UG/ref=sr_1_fkmr1_4?ie=UTF8&qid=1472104386&sr=8-4-fkmr1&keywords=cold+weather+cat5
That's the same spools I used when I lived in Utah to run outside cables. Temps ranged anywhere from -15 to 10 on a normal snowy day and never had issues.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
Here's bunch of cables : http://www.digikey.com/short/3hq8h4
From -70c .. 105c  to regular -40c .. 80-90c  - sorted by this, so don't get shocked that the first entry costs $1000  .. some entries are for 15m of cable, some are for 150 meters, some for 300 meters ... scroll and search until you find the perfect match for you. Also some entries are for cat5e cables with only 4 wires instead of 8 wires so ignore those.
Another good store : http://www.newark.com/unshielded-networking-cable or http://www.newark.com/shielded-networking-cable  ( replace newark.com with farnell.com  if you're in Europe)
Not quite as easy to sort by temperature, but you can sort by jacket material. Just pick one jacket material and open the datasheet for that cable and you'll see the temperature range. Pretty much all the other cables with that jacket material will support that range of temperatures give or take 5-10c.
Still, they kinda tend to sell by spools of 300 meters or 150 meters, something like that.
Ubiquiti ToughCable is always a good option - have used it before in 35+ heat without issue.
Generally cables can handle cold pretty well as long as they do not move at all - they become brittle. Having them insulated in some way against the heat cycle of day/night also will prevent the copper being damaged by expansion and compression
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
I can't find that exact model here on Amazon.ca, but I found this:
https://www.amazon.ca/Ethernet-Waterproof-Outdoor-Underground-VIVO/dp/B00AWQ13R6/ref=sr_1_2?ie=UTF8&qid=1472153504&sr=8-2&keywords=direct+burial+cable
Mobile: Nexus 6P
I found some waterproof direct burial cable: https://www.amazon.ca/Ethernet-Waterproof-Outdoor-Underground-VIVO/dp/B00AWQ13R6/ref=sr_1_2?ie=UTF8&qid=1472153504&sr=8-2&keywords=direct+burial+cable
I live in Canada, so shipping would get expensive. I will still take a look
thx
Mobile: Nexus 6P
Im thinking of putting the ethernet in some kind of conduit up the wall until it reaches the soffit.
Mobile: Nexus 6P
15 hours ago, Member said:
Hi,
thanks
http://www.monoprice.com/product?c_id=102&cp_id=10234&cs_id=1023405&p_id=12732&seq=1&format=2
best cable money can buy or at least one that wont make the bank go bankrupt . its a bit stiff but works well i have the 250ft spool of it . dont run indoor cable . you "should be fine but "its not going to last forever if any water gets on it /in it
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
That's a crap cable.  It's made of CCA (copper clad aluminum, basically a cheap version of network cable by using aluminum instead of copper and just copper plating each strand to make it look like it's completely copper) , which sucks and shouldn't be used for lengths longer than 20-30 meters. It's not ideal to use in places with large variations of temperature as the aluminum and the copper will shink and expand at various degrees inside the insulation and will eventually degrade.
The waterproof outdoor underground thing in the name is crap, it's basically just a plastic sheet foil the cable is wrapped around. Best, proper underground cables (check fiber optic cables) usually have a kind of sticky glue like substance on them and afterwards they're wrapped in a second layer of pvc or something thick... that sticky substance is kind of a rat and squirrel repellent, rats will chew on the cable but at least there's a chance they'll stop once they lick that substance. Here's an example: http://www.okidensen.co.jp/en/prod/cable/lan/mouse_lan.html
You can buy plastic "tubes" to push the network and power cable through, i think they're called electric raceway or something like that in US.  Here's an example: https://www.platt.com/platt-electric-supply/Electrical-Conduit-Wire-Duct-Electrical-Raceway/Non-Metallic-Raceway/search.aspx?SectionID=3&GroupID=45
Some come with double adhesive tape on one side (but i doubt the tape would last at outside humidity or cold) and some come with screw holes at even spaced intervals on the raceway which would allow you to drill into the house wood and screw the raceway in place.
Spend a bit more money on network cable if it's for cameras outside, it will save you the trouble later on. Buy real copper and i'd personally prefer cable made with strands of copper, not solid core.
And by the way, there's also a Canadian version of newark / farnell : http://canada.newark.com/shielded-networking-cable or http://canada.newark.com/unshielded-networking-cable
If you want something cheap but good (better than that vivo cable), have a look at this : http://canada.newark.com/pro-power/cbbr6332/shielded-multipair-cable-4-pair/dp/60R4035
It goes only as low as -20c but like others said, as long as it's not moved while it's cold it should be fine. It also has an extra layer of aluminum foil to protect the internal wires so it should be fine.
Make sure you use network jacks designed for solid core wire, there's two types (one for stranded wire, one for solid core)
I think I will get that cable then:  http://canada.newark.com/pro-power/cbbr6332/shielded-multipair-cable-4-pair/dp/60R4035
I will also buy some conduit to prevent UV damage and tampering.
thanks
Mobile: Nexus 6P
thanks
The one you showed me is solid core right?
Mobile: Nexus 6P
@Member
You can also buy network jacks and other accessories from the same website if you want, save you money in shipping costs.
This one will work for both solid and stranded core nework cables : http://canada.newark.com/aim-cambridge/32-5998ul/cat5-rj45-modular-plug-8-position/dp/66K8784
They're a bit more expensive but believe me, they're much better quality compared to no-name network jacks you'd buy from local stores, the contacts fit better, the plastic channels are better, the plastic may be stronger and flex less and so on.
If you don't have crimping tool you can buy one from there as well, but good ones are kind of expensive . There are cheap crimping tools, but ideally you'd buy one that presses directly on all pins.
I'm talking about this design, but I don't recommend buying Duratool brand, it's not that great imho : http://canada.newark.com/duratool/ht-n468b/crimp-tool-ratchet-207mm-modular/dp/60R2634
This design where the tool pressed on all contacts at the same time, instead of behaving like scissors pressing some contacts sooner than others.
ps. yes, the cable i linked to IS solid core, just check the page:
Product Information
LAN Category:Cat5e
No. of Pairs:4 Pair
Wire Gauge:24AWG
Conductor Area CSA: 0.52mm²
Reel Length (Imperial): 1000ft
Reel Length (Metric): 304.8m
Jacket Color: Grey
No. of Max Strands x Strand Size: 1 x 0.52mm
Voltage Rating:-
Jacket Material:PVC
Conductor Material:Copper
External Diameter:6mm
Product Range:-
SVHC:To Be Advised
13 minutes ago, mariushm said:
snip
Thanks. This may sound dumb, but Cat5 network connectors will still deliver the speed of cat5e right?
Found this:
https://www.amazon.ca/Ethernet-Tester-Crimper-Connector-Network/dp/B017X4RAXK/ref=sr_1_1?ie=UTF8&qid=1472173450&sr=8-1&keywords=ethernet+tool
Mobile: Nexus 6P
Yes, those network jacks I recommended will work just fine with cat5e speeds, there's basically no physical differences between Cat5 and Cat5e when it comes to jacks. The differences are only in the way the cables are built (how many twists per inch each pair of wires has, how many twists per inch are between the four pairs, the quality and thickness of the insulator on each of the 8 wires and so on, cable makes all the difference, the jacks are the same).
Cat6 and Cat6a jacks impose some restrictions regarding how much length of wire can be untwisted inside the connector, and overall the jacks have to be built to a much higher standard and usually also have some metalic insulation around the plastic jack for electrical interference shielding and so on.
Regarding that crimping tool, it's the typical cheap stuff, it will probably do a few tens/hundreds jacks without any problems but on such cheap tools the metal is usually of somewhat poorer quality and in time the tool may no longer apply enough pressure (or apply pressure evenly) on the pins to crimp connectors properly.
My advice would be not to spend so much money on a pack of tools you will probably not use, you should buy just a RJ45 crimping tool as a standalone item. You won't use the network tester very often and some computers have cable testing features built into the BIOS or as an utility on the drivers CD / website and the other items in the package you will probably also not use at all.
49 minutes ago, mariushm said:
snip
Okay, thanks for the explanation.
I should just buy the crimping tool from the Newark, bit expensive.
I am planning to use the crimper tool for a few times, maybe a cheap one would suffice.
BTW, I am setting up surveillance cameras connected by PoE.
Mobile: Nexus 6P
21 hours ago, Member said:
Hi,
thanks
https://www.amazon.com/dp/B002HFEBYM/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1944687682&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B001B6C5H8&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=QY0S26ZGBTA58JM676KE
Not nearly as expensive as the industrial stuff but hey I have used it Michigan, California and Texas
Got a few years ago as a Cat5. Got Cat6 for my New House in Texas this august
In Michigan one winter the low was -12F, 3 feet of snow the whole day was sub zero and it literally was frozen some parts was under snow it had survived and operated fine. Moved to California. Fine. Moved to Texas the hottest day since September 2014 when I moved there was 107F again worked fine and mind you in direct sunlight and it being a black cable your mileage shouldn't be affected. (Yes I got the 300 Foot ran it from the security cam into a little drilled opening which is sealed then runs from the little space on roof to the nearest Cat5e port)
Update: Yes I have gotten this for 5 different houses on 5 occasions. 4 Times a cat5 and August 2016 I opted for cat6 for my new house
Build Name:
Anton
CPU: I7 4790K
GPU: ZOTAC RTX 2060 SUPER AMP EXTREME
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
CASE: COOLER MASTER N300
PSU: THERMALTAKE 600 WATT
STORAGE: TOTAL 6.5TB, 512GB SAMSUNG 850 PRO BOOT DRIVE, 2TB HDD 1, 2TB HDD 2, 2TB WESTERN DIGITAL USB 3.0 BACKUP DRIVE
- CRACK!
Thx for the reply.
Im currently looking at this: http://canada.newark.com/pro-power/cbbr6332/shielded-multipair-cable-4-pair/dp/60R4035
Pretty good price and can withstand -20C
will take a look at that link
thx
Mobile: Nexus 6P
The thing with that http://canada.newark.com/pro-power/cbbr6332/shielded-multipair-cable-4-pair/dp/60R4035 it will do better in the heat but in your cold climate it will suffer try to get something that will do better in cold like what I suggested the thing is it will never get 158F the hottest it will get I canada would likely be 100F even in direct sunlight that will not get any hotter than 120-130F but IT WILL get well below -4F or -20C in your area as you state
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
might have to wrap the etherenet cable in something?
Mobile: Nexus 6P
