Outdoor ethernet cable (withstand -30C)
Member
13 hours ago, Savageiste said:
The thing with that http://canada.newark.com/pro-power/cbbr6332/shielded-multipair-cable-4-pair/dp/60R4035 it will do better in the heat but in your cold climate it will suffer try to get something that will do better in cold like what I suggested the thing is it will never get 158F the hottest it will get I canada would likely be 100F even in direct sunlight that will not get any hotter than 120-130F but IT WILL get well below -4F or -20C in your area as you state
polyolefin insulation might help. I saw the super premium ethernet cables using this material as an outer coating.
Desktop: i5 4670k, Z97-K, 16GB, MSI GTX 770, Evga 850G2, TT T31
Freenas Server: i3 4170, X10-SLL-F-O, Crucial 16GB UDIMM, 4x4TB WD Red, Evga 550GS, Fractal 804
Peripheral: K60, HyperX Cloud
Mobile: Nexus 6P
22 hours ago, Member said:
might have to wrap the etherenet cable in something?
Maybe an additional layer of insulator
Build Name:
Anton
CPU: I7 4790K
GPU: ZOTAC RTX 2060 SUPER AMP EXTREME
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
CASE: COOLER MASTER N300
PSU: THERMALTAKE 600 WATT
STORAGE: TOTAL 6.5TB, 512GB SAMSUNG 850 PRO BOOT DRIVE, 2TB HDD 1, 2TB HDD 2, 2TB WESTERN DIGITAL USB 3.0 BACKUP DRIVE
- CRACK!
