x99 quad channel two 4x4g kit's
Solved by done12many2,
5 minutes ago, Psittac said:How do I want each kit installed? Should each channel have one from each kit or should each channel be a matched piece?
Put one matched set on the A/B channels and the other matched set on the C/D channels. If you have an Asus motherboard (maybe some other brands too), you can control DRAM voltage separately for A/B and C/D. This will allow for independent adjustments should you need to overcome any quality differences between the sets.
