Hyper 212 evo vs Stock cooler help
Superguy4ever
I am currently in the process of choosing parts for a pc build i want to be using for Blender, game creation and some gaming. I have a tight budget (kinda) so i choose the i5 6500 since it has a very good speed and a very good efficiency level as one skylake core almost equals two of AMD's older cpus core (DONT START AN INTEL VS AMD BATTLE XD). Anyways, i would like this pc to last me around 3/4 years so i want to keep the cpu as cool as possible to allow it to achieve that lifetime. I was wondering, does the stock cooler manage to keep the cpu below 70 degrees (the temperature recommended by Intel for the cpu to maintain a long life time) or is it worth spending those $50 (i know its $30 in America on Amazing/Newegg but bcause of shipping its $50 in my country :( ). If i dont spend those $50 on the CPU Cooler i could spend them on getting a better mobo with 2 pcie 3.0 slots to allow me to add a second graphics card down the line if the one I pick becomes less effective later) or i could spend them on getting a better graphics card now.
its worth it if you want it to last for very long
Mouse: Logitech g402 <3
Keyboard: Some Tenkeyless with blue kalih switches
Headphones: Logitech g430
Monitor: HP w2207h (1680 x 1050 @ 60hz)
PC Specs:CPU(AMD A8 6500 @3.5ghz), Mobo ( ASUS A68HM-E  FM2+), 1x1600mhz 4gb stick of ram, Random grey PSU, 920gb ssd
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
Laptop:Toshiba satelite with 8gb of ram a 480gb ssd and a mobile 2nd gen I3
Got one, keeps my i5 4690K at 58° C max under load (not oc'ed tho)
Hail Hydra #shieldcomegetme #9minutes
Get a decent cup cooler the stock is a fail and then save up money for the mb
If the ambient temps are below 27 C then the stock cooler should be able to keep the 6500 below 75C ( 75C is what I consider a fine max allowed temp) but if you live in a warmer climate and frequently get 30C+ ambient temps probably not at least in the summer
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
Ok good try to oc it but keep voltages as low as possible
Is 35 C considered a warm temperature? xDxD
Yeah, that would be a no on the stock cooler keeping it cool, the tropics make PCs sad since they don't like the heat
the new Intel coolers are kinda' shitty, not like the old coolers that worked for decades
the 1st to go is the fan
the stock fan will keep it cool as long as it working - the i5 6500 is not a "hot" CPU
ps: I own one and I have it with the 212EVO
The stock cooler is fine.
If you're referring to the tcase temp of 72c, that refers to the IHS. The cores themselves are fine up to 80-90c at load.
Well, i live in some of the world's most extreme temperatures are you sure my CPU will be fine and will maintain a long lifetime with the stock cooler?
Yes. They wouldn't ship the cpu with the stock cooler if it wasn't adequate.
Ok then, thanks for the help :)
Stock cooler is just fine for locked CPU. Only reasons to get anything else are looks and noise. Stock will be able to keep CPU cool enough that it will last for 7+ years. Only if CPU is run under high voltage  (not issue since its locked) or 24/7 at 90+C, lifespan would be a thing.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
