What "part" do you want?
https://linustechtips.com/topic/624102-photoshop-cc-help/#findComment-8053671
1 minute ago, Carlos1010 said:
The left part because on YouTube they have the channel,paths,layer thing. HELP
What youtube are you talking about? Post a link?
Channel, paths, and layer menus are all on the right side not left...
https://linustechtips.com/topic/624102-photoshop-cc-help/#findComment-8053698
It's because you can customize your window setup, like any good program. Take a look in the Windows section (in the toolbar above) and see what windows you need. You can detach and move the windows to wherever you want. For example, in the video on the left I see they have detached the tools window and made it smaller.
https://linustechtips.com/topic/624102-photoshop-cc-help/#findComment-8054841
