What is important for sound quality?
TommyTwommy
So I think there are 3 factors in play here.
The quality of the sound file itself. Bitrate and bit depth. Right?
The amplifier
The speaker
So lets say the sound file quality is high.
Case 1: Now we have the amp and the speaker. Lets say we have good speakers as well. If we connect them to a shitty amp vs good amp will it matter?
Case 2: And the other way around. If I have shitty speakers and connect them to a shitty amp vs good amp, will it matter?
In which case would the difference be more notable, why? Pls explain
I'm asking this because when I connect my earphones to my smartphone THEY SOUND AMAZING. When I connect them to pc frontpanel they are fkn shit. But also because I'm interested how all that audio stuff works.
CPU & COOLER - INTEL i9 12900K | NZXT KRAKEN X62
MBO - MSI Z690 EDGE
GPU - ASUS GEFORCE RTX 3080 TUF
RAM - 2x16GB KINGSTON FURY 3200MHZ
PSU - PHANTEKS REVOLT PRO 1000W 80 PLUS GOLD
SSD #1 - CORSAIR SN850 1TB
SSD #2 - CORSAIR SN850X 4TB
SSD #3 - INTEL 660p 2TB
CASE - PHANTEKS ECLIPSE P500A D-RGB
MOUSE #1 - LOGITECH G502 X Wireless
KEYBOARD - AKKO 5108B PLUS
SPEAKERS - SVS PB-1000 + 2x ADAM A3X
HEADSET #1 - SENNHEISER IE-300
HEADSET #2 - FOSTEX TR-X00 PURPLEHREART
AMP/DAC - MAYFLOWER ARC
OS - WINDOWS 10 PRO
DISPLAY 1 - LG OLED42C2
DISPLAY 2 - XIAOMI 2K GAMING
PHONE - SAMSUNG GALAXY S23+
PC front panel audio has a lot of EMI due to the way the front panel wiring crosses over power cables
this is not a problem with your PC audio amp
try plugging your earphones into the back panel audio output instead, or use an extension cable going to the back
5 minutes ago, berny22 said:
-snip-
I don't think amps matter that much in terms of sound quality. To me they just power speakers/earphones/headphones. What matters most imo is the processor.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
Isn't the processor in the amp? Sry, but I reallly don't know how audio works.
MBO - MSI Z690 EDGE
OS - WINDOWS 10 PRO
Okay let me break this down as simply as I can.
The speakers matters the most, when it comes to audio quality, the amp is a bit more weird beast, you see if the amp is okay and can power the speakers fine then you are fine, since it is only ampliflying the signal the dac is sending out. Okay now the file, that is when we get to the really weird stuff, because you see a mp3 with a good master can sound 100% the same to the human ear as a 24bit FLAC file with a good master. So a good quality mp3 can sound just as good as a higher quality file..
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
WAIT WAIT, Looks like I got the question wrong. I thought the DAC and the AMP is the same thing. Whats the difference. And answer my question as if I the amp was DAC in my case.
MBO - MSI Z690 EDGE
OS - WINDOWS 10 PRO
DAC= Digital to analog convertor
AMP= Amplifier
They are seperate. But most things that come with built in audio nowadays will have both. You'll often see people mention DACs, those are processors.
Soo, let me remake the question.
Case 1: Now we have the amp dac and the speaker. Lets say we have good speakers as well. If we connect them to a shitty amp dac vs good amp dac will it matter?
Case 2: And the other way around. If I have shitty speakers and connect them to a shitty amp dac vs good amp dac, will it matter?
Now I know
1. Speakers -> MOST IMPORTANT, although I'm rly doubtful about that cuz I expreinced something else in reallife as I said above
MBO - MSI Z690 EDGE
OS - WINDOWS 10 PRO
I also have this nice post about amps and dacs and the same principles also goes for speakers.
You will need a amp for the speakers unless they are powered speakers (build in amp) and you also need a dac to make the digital file to analog, but the one your pc has build in is fine.
Now I know
You will need a amp, so you can power the speakers, unless they are active speakers, the DAC that is build into your mobo in your pc is fine, unless you have problems with onboard.
So what makes my earphones sound shitty when i plug them to my front panel pc. And make them sound like a 1000€ earphones when they are plugged to my smartphone
Isn't the pc suppoused to have a better ... THING THAT MAKES SOUND BETTER .... inside that my smartphone
MBO - MSI Z690 EDGE
OS - WINDOWS 10 PRO
Describe 'shitty'. What motherboard do you have?
Not as loud. Worse sound quality. ASUS M5A97 R2.0
MBO - MSI Z690 EDGE
OS - WINDOWS 10 PRO
That can depend on a lot of things.
1. Do you have background noise?
2. You might like how the phone colors the sound
3. simply bad onboard/ old mobo
4. bad quality music
Just give me a budget for the setup and I can see what I can find that will be good and please tell me the use case.
Okay, I'd probably put it down to the motherboard's onboard audio being crap. What phone are you using?
And there's the question my asking.
You said 'motherboard's onboard audio' what is the thing inside that that makes shitty sound. Is it the amp , the dac or something else?
I'm using an HTC One Mini 2
MBO - MSI Z690 EDGE
OS - WINDOWS 10 PRO
onboard is the build in amp and dac that is on the motherboard, so it is maybe a mix of a bad amp and a bad dac.
As I said, anything that has built in audio nowadays has both an amp and dac just like your phone. DAC processes the files and amp drives whatever you plug into the jack.
I don't know much about the HTC One Mini 2 but I have used an M8 and the sound qualifty from that was pretty good.
I don't need to buy anything. I just found out about the whole DAC/AMP thing. Before I did. Audio for me was PC or SMARTPHONE->CABLE->SPEAKERS = SOUND and not
AMP & DAC -> CABLE -> SPEAKERS -> SOUND
I found out about AMP - DAC when I was trying to connect my home theater to my pc. And when I tried to connect speakers directly to my pc that are suppoused to have an amp but I didn't know about it then and thought the speakers aren't working. (I connected the speaker (a 80W/6OHM speaker) directly to my pc with a 3.5mm jack)
MBO - MSI Z690 EDGE
OS - WINDOWS 10 PRO
Other name for HTC One Mini 2 is HTC One M8 Mini .. So its the same phone with almost same components just smaller. It has the BoomSound thingy
MBO - MSI Z690 EDGE
OS - WINDOWS 10 PRO
I found out about AMP - DAC when I was trying to connect my home theater to my pc. And when I tried to connect speakers directly to my pc that are suppoused to have an amp but I didn't know about it then and thought the speakers aren't working. (I connected the speaker directly to my pc with a 3.5mm jack)
Can I get a pick or a model of those speakers, because unless they are active speakers you can't just connect them with onboard and if they are more than 2.1 you will need a receiver.
Lol, nah that little amp on the motherboard would not be powerful enough to drive speakers.
Can I get a pick or a model of those speakers, because unless they are active speakers you canøt just connect them with onboard and if they are more than 2.1 you will need a receiver.
OH I already connected it all xD
Its an LG Home Theater, model: LH-T6340. The speaker setup is 5.1. 5x60W and a 120W subwoofer. The hometheater is connected to the pc over a 3.5mm to RCA cable.
MBO - MSI Z690 EDGE
OS - WINDOWS 10 PRO
