A swede needs help with troubleshooting!
Hello guys!
I am a swedish person(excuse my english)who considers himself to be quite handy when it comes to computers but I am at an impass with this problem, so I need your help!
I recently upgraded my computer, and when I say that I mean I bought everything except a new graphics card. Details below:
CPU: i7 6700k with corsair H75
MOBO: asus z170 pro gaming
RAM: Corsair vengeance DDR4 2x8GB
GPU: geforce GTX 770 gainward phantom
PSU: Fractal Design EDISON M 750W
HDD's: Samsung 120GB SSD and a 1TB drive
Windows 10
Now, it seems that anytime I do anything thats "graphic intense" such as witcher 3 and Rust, yes I know, but not CSGO or dota. I will get a message saying the graphics driver has stopped working and been reset. I have tried everything I can think of, completley wiping graphics drivers, downclocking the card(worked on my old rig when I was playing rust)made sure the drives are ok aswell as RAM to be sure. So here I am, a lonley swede who might be on the brink of a serious meltdown(which means hitting my pillow and not talking about it alot in swedish)
So please some kind soul, help meeeee!
Thanks, il provide any info you need if I missed something.
EDIT: new to this site, did not know what topic to put this in so if its in the wrong one, im sorry :D
Just now, Kungen said:
mhm. did you use ddu?
how are the temps?
maybe something went wrong with the windows installation?
maybe the psu cant deliver enough power at full load. better check the connnectors.
when you get a driver report its probably not the gpu beeing instable because otherwise you would get artifacting or crashes.
welcome to the forum by the way.
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
how are the temps?
Yeah, I used DDU
the temps are fine, monitoring with MSI Afterburner
Yeah, thats where I am at basically, hoping it wont come to that.
Yeah, il check it now.
Well i kind of failed to mention that the game always crashes and some small artifacting can be observed right before the crashes.
Thanks, been watching Linus content for a long while, figured I could get some help here.
it would be very weird if the chip was unstable after just 3 years. maybe try to raise the voltage a little and decrease the clockspeed at the same time. if this helps your chip is in bad condition.
maybe your gpu is telling your to get a rx 480 :D
try reseating the graphics card if you haven't already, and clean the contacts on the card with a pencil eraser, might be that it's just not making proper contact and when it gets a heavy load it freaks out because of that
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Yeah, well, thing is, I donw know if MSI Afterburner clock is actually taking, since the numbers are not changeing after i press "apply"
Yeah, if by resetting you mean deleting the drivers with DDU etc then yes.
no he mean taking the card out and cleaning the contact points.
maybe contact the support of gainward. sometimes those guys are incredebly helpful.
He meant that aswell I think, freaky thing is, I took the card out, put it back in, and Rust did not crash, gonna do more testing tomorrow. Dont want to get my hopes up just yet!
TURNIP (geddit? Swedes are cross between turnip and cabbage so...k nvm) /s
Try downgrading to Nvidia drivers 362.00 as nvidia drivers have been pretty bad recently, I have had a few problems myself with the new drivers.
hello!
is it me you're looking for?
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
Cooler: Dark Rock Pro 3
RAM: 32GB DDR4
GPU: GTX 1080
Storage: 1TB 850 Evo, 1TB HDD, bunch of external hard drives
PSU: EVGA G2 750w
Peripherals: Logitech G502, Ducky One 711
Audio: Xonar U7, O2 amplifier (RIP), HD6XX
Monitors: 4k 24" Dell monitor, 1080p 24" Asus monitor
Laptop:
-Overkill Dell XPS
Fully maxed out early 2017 Dell XPS 15, GTX 1050 4GB, 7700HQ, 1TB nvme SSD, 32GB RAM, 4k display. 97Whr battery :x
Dell was having a $600 off sale for the fully specced out model, so I decided to get it :P
-Crapbook
Fully specced out early 2013 Macbook "pro" with gt 650m and constant 105c temperature on the CPU (GPU is 80-90C) when doing anything intensive...
A 2013 laptop with a regular sized battery still has better battery life than a 2017 laptop with a massive battery! I think this is a testament to apple's ability at making laptops, or maybe how little CPU technology has improved even 4+ years later (at least, until the recent introduction of 15W 4 core CPUs). Anyway, I'm never going to get a 35W CPU laptop again unless battery technology becomes ~5x better than as it is in 2018.
Apple knows how to make proper consumer-grade laptops (they don't know how to make pro laptops though). I guess this mostly software power efficiency related, but getting a mac makes perfect sense if you want a portable/powerful laptop that can do anything you want it to with great battery life.
Well, it seems I was wrong about the temp thing, at 80c I start to see artifacts and it soon crashes, this is however new, the card did not get this hot in my old build.
Thats rather odd, 80C should be fine for your graphics card. Maybe try an aggressive fan profile in MSI Afterburner?
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
Well, I tried that, and it seems to do the trick, atleast in rust. I ran furmark aswell but it did not go over 80c and it went smoothly. This is seriously starting to wreck my brain... If this is the problem raising the fan profiles seem to be a temporary solution, I dont want a card that seem to crash at 80C obviously
