Razer Blade Stealth worth it?
Solved by Dackzy,
1 minute ago, krkevin said:Yes, I do. It's near impossible to have that much power in a slim body, and not be hot at the same time. I won't be bothered by heat, since I rarely play graphic intensive games. The most I'll play is either CS:Go, and maybe other games if I can afford them.
It will get really hot under CSGO, but fair enough if you want to get it
Featured Topics
Fio ·
Posted in Troubleshooting0 -
Fio ·
Posted in Networking0 -
Nervoussoup101 ·
2
5
1
pourint ·
Posted in Troubleshooting1 -
1
2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
