good cpu cooler for skylake 6700k overclocked
Solved by aisle9,
Nothing's going to beat the NH-D15. If your case, motherboard and wallet are big enough for it, it's second to none. If you can't quite afford it, the NH-D14 isn't far behind.
If you want something smaller and/or cheaper, check out the Cryorig H5 series and H7, the Thermalright True Spirit, anything by beQuiet or the Phanteks TC-12DX.
I wouldn't do anything smaller than a 120mm tower cooler for a 6700K unless it was an ITX build, so the L9i is more or less out.
