Terrible sound quality after doing a system restore
Solved by dukethedj,
22 hours ago, Enderman said:event viewer just shows you all the logs and you can see the errors of stuff that goes wrong
sometimes you can fix them by googling the error and finding someone that has solved it
most of the time there are tens or hundreds of errors though, so clean install is the best option
So I did a clean install and I got stereo to work properly but its my headphones that are just doing something. I guess my phone had a massive bass boost enabled. I don't know how they could do this, though. I kept the volume and bass at a reasonable level, but I guess things just happen. Thanks for the help.
