Parts/to-do in spoiler. View Post #2 for pictures!
Hello everybody~ Building a new SFF mATX rig to place in a new office building along with some new furniture :) I'll be taking lots of full-res pictures, so stay tuned! Theme of the build will be White, Red, Black with a hint of stainless steel accents.
Here's the components:
i7 4770k - Bought
Asus Maximus VI Gene - Bought
4x8GB 1866 CL9 Dominator Platinums - Bought
Silverstone Tundra TD02 - Not sold anywhere in Canada! Trying to get a hold of one! Ended up buying off Amazon.com
256GB Samsung 840 Pro (boot) - Bought
1TB Samsung 840 Evo - Bought
Silverstone Strider Gold Evolution 750W - Bought
Asus Xonar Essence STX - Bought
Parvum S1.0 White & Red Case - Bought, waiting for it to ship Arrived
Asus 5870 v2 (reusing old video card til 9xxx series cards come out / Maxwell / Volta.) Looking for r9 290s atm. Asus r9 290 DCUII is too fat to fit. Perhaps MSI gaming edition...
Peripherals:
Asus MX279H - Bought
Some white mouse - Haven't decided yet Bought M95 White
Some White Mech Keyboard - Gonna try and source a Filco with custom Thick PBT Keycaps. Bought Ducky YOTS MX Black w/ IMSTO fat O-rings and black anodized aluminum space bar! Trying to find some PBT keycaps now... Just paid for some Red on White Thick PBT keycaps on GH. It's going to look awesome with the red/white theme!
Steelseries 7H - Had it for a couple years, but didn't use it much.
Need to order/purchase:
- Custom Red/White/Black sleeving and wires from Lutro0. Going to make my own short custom wires. Will be crimping each cable and sleeving them heatshrinkless style!
- Fans! Trying to find good looking 80mm white fans that aren't discontinued! Will probably end up using the 80mm fan holes as a passive exhaust. All 120mm fans will be intake.
- PlastiDip. Going to try and spray paint some black fans.
https://linustechtips.com/topic/57790-project-zeal/
September 23: Assembled rig onto motherboard box. Pretty ghetto setup while I wait for my case to arrive.
September 28: 1TB 840 Evo was ready for pickup after I special ordered it :P
October 3: Something in the mail...
October 4: YOTS #754/999 arrives!
October 23: Parvum S1.0 Case arrived!
November 2: Some pics of the S1.0 Case & Keycaps
January 10: Started sleeving & making custom cables. (Thumb and index fingers are burning right now)... TD02 Arrives and I open her up!
January 11: 24pin complete! Custom wire, hand-crimped, sleeved!
January 12: USB 3.0 Sleeved!
January 16: EPS 8 pin & Molex Sleeved.
January 28: Test powering the custom wires. Quick n Dirty OC.
February 8: Sleeved my PSU's Power Cable & sleeved some Mini & Micro USB cables.
Last updated Feb 8.
https://linustechtips.com/topic/57790-project-zeal/#findComment-783132
any reason  your waiting for maxwell and not AMD Hawaii ?
bf4 is around the corner and maxwell is a bit far away
everything else looks great
http://www.youtube.com/watch?v=tkRE1bun6P8
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/57790-project-zeal/#findComment-783139
My options are open right now. I'd like to see what AMD and NVIDIA bring to the table. This'll be an office rig, so it wouldn't be appropriate to be gaming too much on it!
I'm interested in seeing what kind of raw power AMD will bring with Volcanic Islands, but at the same time I'm also interested in NVIDIA's unified virtual memory and Stacked DRAM for Volta.
https://linustechtips.com/topic/57790-project-zeal/#findComment-783145
for an office build its overkill no ?
dual core ivy/haswell mini itx  and  small case like a FT03 mini
maxwell is coming Q1 and volta is pretty far
since this isnt a gaming rig  do u  really need a gpu at all ?
https://linustechtips.com/topic/57790-project-zeal/#findComment-783150
your avatar doesnt match the cpu ;)
Appelzaadje - the Insane
Intel i7-4770K - Maximus VI Formula - Corsair Dominator GT 1866mhz - R9 290X - Xonar DGX - Samsung 840 Pro 256Gb - 3X WD1001FALS - Raven RV01 - Iiyama B2409HDS 3x - Custom water loop - Windows 10 Pro - XFX tripple monitor stand - Steelseries 4HD - Logitech G9, G19, G35 and Z5500
https://linustechtips.com/topic/57790-project-zeal/#findComment-783242
i7 4770k - Bought
photo-15406.png?_r=0   -.-
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/57790-project-zeal/#findComment-783320
Maxwell isn't coming q1. It's 20nm, which won't be ready till late q2, and even then it won't be till q3 or q4 that cards built on that process will be ready.
Daily Driver:
Case: Red Prodigy CPU: i5 3570K @ 4.3 GHZ GPU: Powercolor PCS+ 290x @1100 mhz MOBO: Asus P8Z77-I CPU Cooler: NZXT x40 RAM: 8GB 2133mhz AMD Gamer series Storage: A 1TB WD Blue, a 500GB WD Blue, a Samsung 840 EVO 250GB
https://linustechtips.com/topic/57790-project-zeal/#findComment-783719
http://videocardz.com/45403/nvidia-to-launch-more-cards-this-year-maxwell-in-q1-2014
Q1 was making news around the net
i guess its a rumor
https://linustechtips.com/topic/57790-project-zeal/#findComment-783726
Looks good to me :)
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
https://linustechtips.com/topic/57790-project-zeal/#findComment-783732
i guess its a rumor
I'm gonna go by tsmc's announcements.
Daily Driver:
https://linustechtips.com/topic/57790-project-zeal/#findComment-783975
yes thats the icon for a extreme version :P the normal k versions are blue :D
https://linustechtips.com/topic/57790-project-zeal/#findComment-784595
Is there a reason you decided to get a 1TB SSD in edition to a 256GB boot drive?
Reliability of an SSD for data/storage, while having the more important programs on the boot. And who wouldn't want a blazing fast SSD for all their data?
And @Appelzaadje, I do in fact have a 980x
https://linustechtips.com/topic/57790-project-zeal/#findComment-785060
Instead of a Filco keyboard, I settled with a YOTS Ducky Shine 3 with MX Blacks and white backlight. Just ordered some 70A super fat red silica gel O-rings from IMSTO to reduce bottom out noise. Just look at the size of it!
Can't wait!
Gonna commence building the rig tomorrow and use my motherboard box as a test bench while I wait for my acrylic case. People are still assembling the furniture as we speak. :P
@103it I was actually looking at that mouse...
https://linustechtips.com/topic/57790-project-zeal/#findComment-789645
that's a sick looking sound card! It's to bad all the cool stuff faces the bottom of out cases.  we all need to stick mirrors of the bottom of our cases.
I was contemplating on having a reverse mATX rig, but then the soundcard's texts would all be backwards and upside down (there's ASUS printed on the side of the card). Since I'll be getting r9 xxx series card, I might as well just look at one with a good backplate. Also most aftermarket coolers blow air onto the card, and having air blowing downwards due to it being upside down isn't the most optimal airflow...
https://linustechtips.com/topic/57790-project-zeal/#findComment-804400
Do you plan on painting that fan itself or just the outside of it.
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/57790-project-zeal/#findComment-804425
The whole fan will be White. Keeping the red ring for contrast.
Be sure to put an even coating, it will make it pretty loud it you don't. I would know :lol:  <_<
https://linustechtips.com/topic/57790-project-zeal/#findComment-804441
wow nice
CPU: 2x Xeon E5 2670 Motherboard: ASRock EP2C602-4L/D16,  RAM: 64GB of 1333 MHz mermory from Samsung (ECC),  GPU: Gigabyte GTX 1070,  Case: NZXT Switch 810, Storage: Samsug EVO 250GB and 500GB, 3x3 TB and 1x1TB  HDD  PSU: Corsair RM 850,  Mouse: Logitech MX Master 2s,  Headset: Beyerdynamic DT 770 PRO black edition (80 ohm), OS: UnRaid with two VMs and Plex
https://linustechtips.com/topic/57790-project-zeal/#findComment-833476
Or a shiny copper partition at the bottom.... Oh no, what have I done :o.
That is a really sexy card though :).
https://linustechtips.com/topic/57790-project-zeal/#findComment-834953
