Why my GTX980ti Hybrid is only using 3.9 MB of 6GB?
RRGT19
I was playing Assasins Creed Syndicate and i saw these numbers and the graphics settings are not at max.
Why I bought 6GB then?.
a game only uses as much vram as it needs
and btw thats 3900MB not 3.9MB
3900MB = 3.9GB
It using 3.9GB ... not 3.9MB you should read next time.
Magical Pineapples
The game doesn't always need to use all GPU memory that is available to it,
Also 3987MB = about 3.9GB, sooo.
CPU: i5 6600k OCed to 4.5Ghz @ 1.35v, GPU: R9 390 Nitro, Motherboard: Asus z170-A, CPU Cooler: H100i GTX, RAM: HyperX 2x8 16gb DDR4, PSU: Seasonic x650, Storage: 850 EVO 500gb, WD 1tb blue, Case: H440 White/Black
3 minutes ago, RGT said:
3987MB is 3.9GB
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
try shadow of mordor or rise of the tomb raider at 2560x1440 and you'll understand why you want 6GB.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
What resolution do you game at? You really don't need that kind of VRAM at lower resolutions. Most of it will be wasted at 1080p.
1080p
85% GPU load...i would assume it's 1080p...
3900MB = 3.9GB
Just now, SeanAngelo said:
3987MB is 3.9GB
let me ask you something else then.
I'm using a 1080p monitor for now.
If i have enought power available, why I can not get 60+ FPS with settings at max, for example GTAV?... that is what the 6GB's are for, or not?.
you seem to be CPU bound...the graphics card is not even working at full...you are getting 85% GPU load in the screenshot...
I have a i7-6700 and 16GB memory ram
Well for 1080p you dont need 6GB of VRAM. If the cpu can't handle a game in this case as your GPU is only using 85%. Vram doesn't mean more performance when the game doesn't need it.
Magical Pineapples
well...the 980ti isnt really meant for 1080p gaming...it's more a 1440p card...and the games you are playing are in the case of unity badly optimized and GTA 5 is CPU intensive...you could tweak the settings in both games to get more frames.
no
more vram does not make your game run faster
and about 60fps at 1080p sounds normal for ultra settings
gtav is a demanding game
just turn some of the settings down
All games need certain amount of VRAM. Requirements are different. The only time I maxed all 6144MB of VRAM was RotTR with ultra textures. Typically, but not always, well optimized games will use VRAM efficiently.
CPU: Intel Core i7 7820X Cooling: Corsair Hydro Series H110i GTX Mobo: MSI X299 Gaming Pro Carbon AC RAM: Corsair Vengeance LPX DDR4 (3000MHz/16GB 2x8) SSD: 2x Samsung 850 Evo (250/250GB) + Samsung 850 Pro (512GB) GPU: NVidia GeForce GTX 1080 Ti FE (W/ EVGA Hybrid Kit) Case: Corsair Graphite Series 760T (Black) PSU: SeaSonic Platinum Series (860W) Monitor: Acer Predator XB241YU (165Hz / G-Sync) Fan Controller: NZXT Sentry Mix 2 Case Fans: Intake - 2x Noctua NF-A14 iPPC-3000 PWM / Radiator - 2x Noctua NF-A14 iPPC-3000 PWM / Rear Exhaust - 1x Noctua NF-F12 iPPC-3000 PWM
1 minute ago, Enderman said:
no
^ This
no
Should I keep Optimal settings from Geforce Experience then?.
use optimal settings then tweak a few things to your liking
See photo attached.
There is always a few steps to change until Geforce Experience think that you can not get more performance.
Is okay if I do that?, If I get more 60+FPS of course...
1 minute ago, RGT said:
See photo attached.
its up to you if you want better graphics or better fps, just find a good balance that you like
im not playing on your PC so i cant choose for you lol
what i want to know.
why if i use full settings i can not get more than 60fps if i have a 980ti using 1080p monitor?
stats say that cpu usage is 51% so the cpu is not the problem.
my gpu is damaged or what?
probably just some software optimizations or something
plus the fact that gtav on ultra is extremely GPU intensive, like i showed you in the benchmark
Play BO3, can easily get 5500mb's on 1080. Prolly more with "that" card.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
