Two audio sources in one headphone?
Not sure if this was resolved or not
Line in(mic) on a pc isn't actually a microphone input its just like a headphone input that lets you send sound in regardless of source. However, if your mobo has stero or other inputs that match your tv you could use them.
So, what you can do is use the tv or a xbox usb-audio to send sound out to the pc. Then the PC will act as the mixer, then use the headphone out on the pc to your headphones and after you tweak the balance with whatever software or settings you should be good,
the cheap way(only cost the line
Teamspeak +
Xbox video and audio>>tv > xboxaudio + pc>>headphones
