[Random Question] How Much of a Difference?
Solved by Blade of Grass,
To clarify everything.
The different resistance model of these headphones will sound abit different.
Resistance just affects how hard they are to drive.
Amps delivery amps (amperage) and volts, resistance is basically how much the voltage is lowered by the load.
Voltage = Amperage * Resistance
Higher resistance with the same amperage gives you more volts.
Putting 600 ohm headphones on an amp for 250 would probably result in low listening levels or next to no sound.
Resistance doesn't affect sound quality, but the same headphones with different resistance will give you different sound properties.
