Difference between sunlight sticks and cold cathodes
Solved by W-L,
If your just wanting single color red LED's yes I would be a good method of hoking them up and powering them just don't overdo it with the length since a fan header can't power the entire 5M roll. Here check under wiring up LED's for general info on it:
http://linustechtips.com/main/topic/407754-modding-faq-common-mods/
