Best case that would fit my needs
Jesbro
Hello LTT community,
It's been over a month with my new GPU, and lately it's starting to heat up my computer quite a bit. I've taken a look inside, and I now realized that the GPU does NOT have any airflow, and the lucky CPU cooler is the only one blowing out air. So, I'm not sure if I need to get case fans, or plan on getting a new case completely. Here's my build for reference:
CPU: Intel Core i5-750 2.66Ghz Quad-Core Processor  (Purchased For $0.00)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  ($213.98 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (Purchased For $0.00)
Total: $213.98
Generated by PCPartPicker 2015-12-19 01:57 EST-0500
And here's a picture of the poor GPU warming up inside: http://i.imgur.com/2d0G8zz.jpg
So, if I need to switch to a new case, which one is the best under $120? I also need it to be AT MOST 21 inches in depth/length, and has to have AT LEAST one optical/DVD drive.
All help is appreciated! Thanks!
a new case would be good. A spec-01 is 50$
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
https://pcpartpicker.com/part/phanteks-case-phes614pbk
there's honestly hundreds different cases you can pick but this one is a personal favourite :)
If you have the option to get a high refresh rate monitor, do it.
Main PC CPU: i7 14700k CPU Cooler: NZXT x62 280mm Motherboard: Gigabyte Aorus Elite X WiFi 7 GPU: Asus Strix 3080ti RAM: Gskill Trident Z5 32gb DDR5 SSD: 990 Pro 2TB, 980 Pro 1TB Case: NZXT S340 Black PSU: Corsair RM1000e ATX3.0
Server: CPU: i7 9700k RAM: Corsair 32gb DDR4 HDD: 36tb Usable SSD: Samsung 500gb NVME Case: Fractal Define R5 PSU: Corsair RM1000e ATX3.0
Corsair 350D/450D
Is there a difference between the two?
How many fans does that one bring?\
I've been eyeballing on that one...though size might be an issue with that one.
tbh, just a case will not help your issues. a case and CPU cooler would be a
better thought to help in CPU cooling.
name branded would be:
corsair 350D
corsair Carbide 88R <-- $50 from newegg
fractal design arc mini r2
and a cooler master 212 plus or evo CPU cooler. you can look to a cheaper case,
but eventually, these are the top mATX branded cases. others seem to either have
connectivity, cable management, or cooling issues.
350D is a mATX case while the 450D is a mid tower case.
the spec 01 has 2 top, front and 1 rear. all being 120 and all but the rear being able to support a 140
corsair 350D
Hmm. Know any cases in the same price range as the 88R?
There's a lot of cases out there. For really good cases though, you have to spend a little bit more to get a good case. And what I mean a good case is: Robust build quality, excellent cable management, good ventilation for cooling, and ease of building into it. My personal favorite which I just got at the time of posting this, is the Corsair 900D. I love massive cases and this is what I consider my absolute favorite after checking it out at Fry's Electronics not too far from here 'till they stopped stocking it for unknown reasons. I'm going to review the case as well. Good cases that aren't super expensive are the NZXT H440, the Corsair 450D, the Fractal Design Define R5, and the Corsair Graphite 730T.
https://pcpartpicker.com/part/corsair-case-cc9011022ww
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
Um...what about any good cheap cases? I'm deciding between the Source 210, Corsair 200R (dunno if I should get 300R for future upgrade), Rosewill Challenger, Cooler Master HAF 912, and N200.
I'm not sure about any good cheap cases. My firsthand experience with cheap cases was with the SPEC-02 case, and that wasn't so fun to build in. If anything I would go for the 300R you mentioned.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
Corsair c70 can be found at about 120$ on newegg.ca
I love this case and will give you nice airflow and expandability.
Its good looking but not quite silent. Its quiet at best
