GTX TITAN X Custom Fan Speed - Dangerous?
Rob.S
Hi there,
I bought a PC with the reference card of the GTX TITAN X. It is in a small form factor PC, reaches normal temps while gaming. But I can make it cool without worrying about the sound, as I have great headphones. Can I set the fan speed to 80 or 100% while gaming without it damaging the fan/card?
- Rob
its fine , if its dangereous why should it be an option then
my rig ( fx-8370@ 4.6GHz / Nepton 240m/ msi 970 gaming / 16 Gb corsair xms / antec VP700P /  aerocool xpredator x1 white / costum rgb lights / r9 290 direct cu2 / 1 TB hhd/ sandisk 128gb ssd / adata SP900 128gb )
peripherals ( steelseries apex / sharkoon fireglider black / razer goliathus / lg25ub55 )
Yes you can.
Why oh why did you get a Titan X...
Because they have a lot of money and not a lot of sense
It should be fine. Nvidia usually dosent let you play with anything that would harm the card (cough, cough, +12Mv, cough).
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
I can do +87 mV on my 970 :o
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
theoretically the high speeds will wear out the fan faster, but i'm sure modern cards are built to take it...
 +12Mv, cough
PLUS 12 MEGAVOLTZZZZZZ -wrestling announcer voice-
because its the best. dont give me the rubbish about a 980ti overclocked will beat a titan x. if you oc the titan x it wont get close
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
Titan X.. 980TI VRAM Edition?
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
BULLSHIT ALERT
overclocked titan x vs overclocked 980ti is a respectable gap and where i am from the 980ti is like 600 and the titan is like 750
1
BULLSHIT ALERT
Because 2FPS is close.
and besides its a titan x. the card isn't completely impracticle. if you want the best performance it is the card to buy
1
For that difference then the titan X was a good decision. However I would like your titan X to go up against my 1562mhz 980ti on air  :P. But yeah the 980ti makes the most sense in America (and some other countries) because its a nice $350+ difference for minimal non OC performance gains, and then if you hit the lottery you get a titan X or better.
But if I was in your situation where it was that much of a difference I probably would have gone with the titan X too.
CPU i7 4770k (4.5ghz OC) | CPU Cooler Swiftech H220-x | GPU 980ti G1 Gaming (1562 mhz) | Mobo EVGA z87 Stinger | RAM 16gb Kingston HyperX Beast 1866mhz | PSU EVGA 850w B-2 | Storage Seagate 2tb hdd 7200rpm(main storage) & Samsung 840 EVO 250gb (boot drive) | Case Corsair 250D
lmao, when I was buying the prebuilt, it was the same price as a pc with a 980
I would have loved the 980Ti...
Yes you can.
Cheers. I'll be keeping the fans up high while gaming. Anyone also know how to do the same thing with the stock intel cooler? I don't own any fan controllers.
