Got a bit of a performance problem with my G1 980ti
EpicNinjaCheese
Go to solution Solved by EpicNinjaCheese,
You simply won't get 200FPS in demanding games. SLI scaling isn't that good and games probably won't even support that refresh rate. The better CPU will not in any way help with what you described. You may as well spring for the 5960x octacore if you want the best.
Naw Damn, haha octacore sounds great but i dont think the 1k + price tag does it for me thanks, plus thats why i posted here to see what everyone else could tell me about it
5930k is the same as 5820k but with more PCI lanes! it's not 'bigger' or more powerful, it's the same, don't overpay.
I do know that and isn't it silly that its around $300 more than the lesser :( You do have a good point
Pretty much this ^ Go for the 5820k. Here's a part list:
[url href=http://www.pccasegear.com/sc/iIi]PC Case Gear - Shared Shopping Cart
1 x [url href=https://www.pccasegear.com/products/28759]Intel Core i7 5820K - $579.00ea
1 x [url href=https://www.pccasegear.com/products/27939]NZXT Kraken X61 280mm AIO Liquid CPU Cooler - $199.00ea
1 x [url href=https://www.pccasegear.com/products/31073]Kingston HyperX Fury HX426C15FBK4/16 16GB (4x4GB) DDR4 Black - $199.00ea
1 x [url href=https://www.pccasegear.com/products/32801]ASRock Fatal1ty X99X KILLER/3.1 Motherboard - $459.00ea
Total: $1,436.00 - @pccasegear.com 02/12/2015
Thanks for your help man, was looking at the corsair ram because it has a 3200mhz clock speed though
Way too low. You should have a score around 18k. Check drivers. Cancel that. I thought you meant your graphicsscore. So everything is fine.
18k? jesus i think someone said earlier that its my physics performance dragging me down, which makes sense
i can't find his post at the moment because this website seems to not want to display all the posts after i pressed refresh
anyway i gotta fly thanks for your help guys, really loving the community on this website
Its the CPU physics score thats bring it down. (Typically seen a lot (even on my system) on i5's vs i7's)
i5's usually always score a few thousand points less than i7's.
The one to watch and compare is his Graphics Score of 18879
Welcome to the forum, enjoy your stay, glad we could help.
Happy Gaming!
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
