Got a bit of a performance problem with my G1 980ti
EpicNinjaCheese
Go to solution Solved by EpicNinjaCheese,
You simply won't get 200FPS in demanding games. SLI scaling isn't that good and games probably won't even support that refresh rate. The better CPU will not in any way help with what you described. You may as well spring for the 5960x octacore if you want the best.
Naw Damn, haha octacore sounds great but i dont think the 1k + price tag does it for me thanks, plus thats why i posted here to see what everyone else could tell me about it
5930k is the same as 5820k but with more PCI lanes! it's not 'bigger' or more powerful, it's the same, don't overpay.
I do know that and isn't it silly that its around $300 more than the lesser :( You do have a good point
Pretty much this ^ Go for the 5820k. Here's a part list:
[url href=http://www.pccasegear.com/sc/iIi]PC Case Gear - Shared Shopping Cart
1 x [url href=https://www.pccasegear.com/products/28759]Intel Core i7 5820K - $579.00ea
1 x [url href=https://www.pccasegear.com/products/27939]NZXT Kraken X61 280mm AIO Liquid CPU Cooler - $199.00ea
1 x [url href=https://www.pccasegear.com/products/31073]Kingston HyperX Fury HX426C15FBK4/16 16GB (4x4GB) DDR4 Black - $199.00ea
1 x [url href=https://www.pccasegear.com/products/32801]ASRock Fatal1ty X99X KILLER/3.1 Motherboard - $459.00ea
Total: $1,436.00 - @pccasegear.com 02/12/2015
Thanks for your help man, was looking at the corsair ram because it has a 3200mhz clock speed though
So a couple of days ago i bought a brand new Gigabyte 980ti G1 from PC Case Gear
I've been experiencing weird problems with performance on this gpu and i'm not quite sure what the problem is.
I got a fire strike performance of only 12650. Is this normal for the G1?
My System Specs are:
I5-4460
8gb ddr3 ram
GA-H97-D3H mobo
980ti G1
1200W PSU
SSD boot drive
500gb WD Blue
2tb WD Black
EDIT: i should also add that i ran it at stock speeds as i haven't gotten around overclocking it yet. Also i have a wireless card installed in my system, will this take pcie lanes of my 980ti and slow its performance?
3dMARK Score: http://www.3dmark.com/3dm/9540613?
Drivers are most often the issue in cases like this. Update them. 12650 seems normal based on my google search. You are a thousand or so behind (the two results were about 13k and 14k) but you are up against X99 systems and the like. Your score seems to be fine to me, if games are bad check your drivers.
Intel Core i7 4770k - 2x Geforce GTX 780 - MSI Z87 MPower Max - Corsair H60 - 8GB Avexir Core Series MPower Yellow + 4gb no-brand DDR3 - Corsair Obsidian 750d - AData XPG SX900 256gb SSD - Seagate Barracuda 3TB (7200 RPM) - Hitachi 250GB 2.5in HDD (3200 RPM) - WD HDD 160GB extracted from iMac via black magic (no specified RPM) - ASUS VG248QE 144HZ 3d Vision Monitor - Logitech G602 - Ducky Shine 3 TKL - AKG 172 HD Headphones - Xperia z2 - Sony Noise canceling earphones -  Nikon D5200 With Bundled Lenses - Windows 7 Home Premium - Blue Snowball iCE - Acer Aspire X with a broken case, AMD A6, and Raijintek Aidos CPU heatsink
Righto so i was right in assuming it was the cpu and mobo limiting my speeds then? I am looking at these parts here https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=519779&action=wish_lists
Get 5820k not the retarded 5930k unless you're going to use multiple (3 and more) GPUs and you need a lot of PCI lanes, and 4x4 kit of RAM cause it can work in quad-channel
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Not necessarily the mobo, but you can't really get a better CPU in that one. I personally wouldn't recommend x99 unless it is necessary. An i5 is more than sufficient for modern games, so if it is gaming you're doing you'll be just fine and better off saving your money. If you really want the upgrade or need it, the 5930k (try a 5820k if you can) is good, but damn is it expensive over there in Australia. Try pcpartpicker to see if you can get them any cheaper and just do a lowest price filter on X99 boards. They don't make crappy x99 boards that much anyway, so you're not really risking anything.
Get 5820k not the retarded 5930k and 4x4 kit of RAM cause it can work in quad-channel
I was looking at a 5820k but then i realised that it doesn't have enough pcie lanes to support 3 way sli and if i am going to upgrade the cpu i may as well save a few more weeks to get one that can support it instead of replacing the thing when i want more performance. Also i am going to buy 2 of those 2 dimm kits making a total of 4 dimm's. (works out to be cheaper that way and i get 3200mhz instead of 3000mhz for the 4 dimm kit)
It does have support for 3-way SLI wtf? It can run 3 GPUs at x8 speed, it just can't support 4.
3 way SLI needs 24 lanes (8 per card). The 5820k supports 28. You can do it, just not 4 way.
yeah what you are saying does make sense but i do intend to upgrade this system in the future to support ultrawide monitors so i was looking for 3 way sli support for upgradibility's sake. I really dont see a point in buying lesser parts and replacing them further down the track. Thanks for the advice though
oh i read somewhere that it didn't. oops :\ and then i would have only 8x speeds as opposed to 16x/16x/8x if i went with the 5930k?
For 3 way SLI, the 5820k is good and the cheapest motherboard you can get is the Asrock Extreme 3 which isn't bad at all. 1440p ultrawide isn't hard enough to run to justify 3 way 980ti.
Doesn't matter, 16x and 8x have practically no difference for graphics cards. Even 2.0 8x is good for modern cards.
okay ill keep that in mind
Okay thanks for your help guys. I'll keep that in mind.
Still leaning toward the bigger cpu though because it would be nice not to have to upgrade in the future. BUUUT if i feel i desperately need the upgrade ill go with the cheaper one
Im looking to run the predator z35 when it comes out which is a 200hz 144p monitor with gsync so do you think i would need 3 cards for that or could i get 200fps out of 2.
Mainly gearing up for star citizen 2.0 release by the way so im looking for high performance stuff :P
Also as i said i am looking for upgradibility in this upgrade (yeah i know sounds funny) so i might be looking at the prospect of getting 2 ultrawide monitors or even 3 in the future which would be totally overkill haha but whatever.
http://au.pcpartpicker.com/p/WLb7sY
 There's what I'd get in your place. The RAM is the best price/gb under 32gb and the rest are the cheapest you can find them new. In an overwhelming majority of cases, RAM frequency does not matter. I bought 2600mhz DDR3 back in the day and do not notice any difference in performance switching to 1600mhz even with today's titles.
RAM speeds do matter in some cases, but not in that one. 2666mhz HyperX fury is just as good and it will most likely overclock to 3200mhz if that's your thing :)
I5-4460
8gb ddr3 ram
GA-H97-D3H mobo
980ti G1
1200W PSU
SSD boot drive
500gb WD Blue
2tb WD Black
Way too low. You should have a score around 18k. Check drivers. Cancel that. I thought you meant your graphicsscore. So everything is fine.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
looks good although i would swap out the cooler for the kraken simply because i want the blue accent lighting instead of the green (kinda got a blue theme goin on)
To be honest i am trying to buy the best i can get and if i can get that 3200mhz ram for a little less than what it is advertised at the moment and not have to fiddle around with overclocking i would be a lot happier. Although i do rather like overclocking it takes time to push the limits and i don't think i have the patience
18k really? wow. I'm running latest nvidia game ready drivers with windows 7 ult 64 bit which was installed freshly today because win10 carked itself
Its the CPU physics score thats bring it down. (Typically seen a lot (even on my system) on i5's vs i7's)
i5's usually always score a few thousand points less than i7's.
The one to watch and compare is his Graphics Score of 18879
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
He's corrected himself. Just the graphics score should be 18k, your total score is being brought down by your physics and combined scores because of CPU.
i edit my post. I thought it was your graphicsscore. Everything is fine.
